Old 04-03-2009, 02:39 PM   #1 (permalink)
Post required info about MS-IT by distance learning
Hello,
I am new member and just want to know about MS-IT. I am looking for MS-IT from distance learning. Could anyone pls suggest which good university offer this cource by a distance learning. TIA
Sherry Rawat is offline
Old 05-03-2009, 03:05 AM   #2 (permalink)
Default Re: required info about MS-IT by distance learning
I did it from BITS Pilani.
Frankly, if you have already done Comp Sc engg, it dosent add any additional knowledge based value. Most of the subjects are same.
Professionally, I have yet to see the value addition.
Only memorable part, for me, was the journey to Pilani and back.
Regards,
Mohit
amohit is offline
Old 10-03-2009, 04:52 AM   #3 (permalink)
Thanks a lot Mohit,
Could you please let me know what is the procedure for applying same... I have to go pillani for papers etc.. TIA
Regards,
Mohit
Old 16-03-2009, 11:21 AM   #4 (permalink)
Check out http://www.bits-pilani.ac.in/dlp-home/
There are examination centers in lots of cities.
Every semester, you need to go to one of the examination center to write the exam. Only the final semester project viva happens in Pilani and that too is optional(if you are abroad or for some reason cant attend the viva in pilani, you can give it using video conferencing).
Also checkout this yahoo groups : http://www.bits-pilani.ac.in/dlp-home/
Regards,
Mohit
amohit is offline
Old 16-03-2009, 01:42 PM   #5 (permalink)
Thanks a lot mohit,
I need some more information like admission date, center in delhi or noida etc... If you dont mind may I have your email ID. TIA
Regards,
Mohit
Old 16-03-2009, 08:03 PM   #6 (permalink)
choudang's Avatar
Does MSU offer the same????
For every action, there is an equal and opposite criticism.
choudang is offline
Old 17-03-2009, 01:57 PM   #7 (permalink)
Yes, I think MSU offer the same.
Old 23-03-2009, 10:22 AM   #8 (permalink)
Originally Posted by Sherry Rawat View Post
Thanks a lot mohit,
Sessions generally start in Aug and Jan. Admission forms are avail in May/June for Aug session and Oct/Nov for Jan session.
Keep checking that DLPD website for the announcement.
Messaged you my mail id.
Regards,
Mohit
amohit is offline
Old 02-04-2009, 09:50 AM   #9 (permalink)
Exclamation Re: required info about MS-IT by distance learning
Hi Mohit! I am also planning to pursue MS through DLP BITS Pilani. The problem is I don't know how to get admission in the same. In website it is mentioned advertisements will be available is first week of april. I am afraid I will miss it. Could you please suggest some contact numbers where i can get the information. Please help me out. Thanks,Chhavi.
chhavi is offline
Old 06-04-2009, 11:01 AM   #10 (permalink)
subscribe to the yahoo group: http://groups.yahoo.com/group/BITS_DLPD/
Folks here keep discussing lot of things including admission dates.
Also, BITS DLPD website will post an online version of advertisement when it comes.
There is no limit on number of admissions per semester so dont worry, you will surely get into the course.
Regards,
amohit is offline
Old 06-04-2009, 11:33 AM   #11 (permalink)
Regards,
amohit is offline
Old 06-04-2009, 11:46 AM   #12 (permalink)
Regards,
amohit is offline
which university for MS degree by distance learning?? Ranger QnA (read only) 1 18-07-2008 09:25 PM
PSP info required!! cooldip10 Gamerz 23 04-06-2006 05:59 PM
RAM info required... Udaya Maurya QnA (read only) 8 20-11-2005 10:19 PM
