Old 08-06-2005, 11:09 AM   #1 (permalink)
bharat_r's Avatar
Default Very slow torrent speed...
I have 256 kbps connetction.....I'm having very slow torrent download speeds (like 1kb/s)
But upload speed is higher.I tried limiting it less than 5 but still my download speed is very low.
I have tried many torrent clients like Azureus,BitComet,BitTornado,ABC,BitTorrent,but no use.
Is there a way to get speeds > 25kbps
_____________________________________
When I googled for this I shows links which tells to change the router settings.
I can't understand what is a router.
bharat_r is offline
Old 08-06-2005, 11:28 AM   #2 (permalink)
bharat_r's Avatar
like this:
bharat_r is offline
Old 08-06-2005, 11:36 AM   #3 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Don't know about others but try this. Install BitComet and then download the file that I have uploaded to Rapidshare and copy paste it to the BitComet installation folder. It worked for me with a 200% boost. Hope it does the same for you. Here is the link...
BitComet Tweak File
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
Old 08-06-2005, 01:10 PM   #4 (permalink)
Another Brick in the Wall
drgrudge's Avatar
The download speed depends on a hell lot of factors.. The number of peers, torrent health, and some site admins also restrict the download speeds.. and all wait till u get a good speeds..
@ctrl_alt_del, that file is already in the installed folder of bitcomet.
drgrudge is offline
Old 08-06-2005, 06:00 PM   #5 (permalink)
bharat_r's Avatar
that file which he gave has different contents(opened with notepad & saw).
speed hasen't increased much...increase is from 1kbps to 3 kbps....still slow..
In my case,no. of seeder/peer is not a problwm I think:
bharat_r is offline
Old 08-06-2005, 06:10 PM   #6 (permalink)
drgrudge's Avatar
^^ It's a problem... only 4 seeds and two leechers at the moment, the health of the torrent (ratio of leechers and seeders) may be good but still it's not enough.
Ok, lemme try out the bitcomet thing.. and i shall post back
drgrudge is offline
Old 08-06-2005, 07:08 PM   #7 (permalink)
which client is that screenshot of?
thegame_rulez is offline
Old 08-06-2005, 07:22 PM   #8 (permalink)
i have had a definite increase in speeds after the tweak..but that is only for small files which are 15-20 mb..i am getting arnd constant 8-9 KB/s..
but for comparatively larger files(500-1 GB) even with a good amount of seeders gets me just 3-4.
Old 08-06-2005, 11:21 PM   #9 (permalink)
bharat_r's Avatar
It was of Azureus.
In Azureus the speeds are desent when the the face is in green ....speed is bad when the face is in yellow.
Yellow means NAT problem.I googled for it & found that the income port must be changed ,I changed to the value given(53000).Now there is a green face there & speeds are a little higher(5-10 kbps).
I used to get speeds of 15+ kbps once.May be all depends on the server & other factors.
bharat_r is offline
Old 09-06-2005, 07:00 PM   #10 (permalink)
selva1966's Avatar
I once tried to download a film and it said download time is 32 days and after one hour of downloading 28 days. I stopped with that.
selva1966 is offline
Old 10-06-2005, 01:35 PM   #11 (permalink)
It was of Azureus.
for u ur net provider must have unblocked the port 53000...but in my case...all the ports are blocked..so no use for me.. ne no. i try gives me a nat error..
Old 10-06-2005, 03:42 PM   #12 (permalink)
sunnydiv
Posts: n/a
her leme try tweak, chinmay reports it worked
Old 10-06-2005, 04:28 PM   #13 (permalink)
Just Do It
Charley's Avatar
Pssst .. what kinda film was it ?
Charley is offline
Old 10-06-2005, 08:59 PM   #14 (permalink)
bharat_r's Avatar
yes..the face became green..but after sometime it turned back to yellow
ISP must have blocked that later.
Really I had the green face for some time.
bharat_r is offline
Old 23-06-2008, 05:46 AM   #15 (permalink)
Default Re: Very slow torrent speed...
i try bit commet and i get 135kb/s
dr.vikasburva is offline
