Old 08-06-2005, 12:24 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Delete codecs ! ! !
is it possible to delete codecs ???
asf, wmv etc ... as some codecs r not working properly ...
ax3 is offline
Old 08-06-2005, 01:28 AM   #2 (permalink)
mariner's Avatar
why do u want to delete them ? why not reinstall. the june dvd has a codec bundle.
mariner is offline
Old 08-06-2005, 11:27 AM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Don't delete them, just a plain reinstall would solve ur problem.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 08-06-2005, 11:42 AM   #4 (permalink)
ax3
ax3's Avatar
tried reinstalling bt it doesn`t work ???
wanna install it freshly ...
... W H O T ...
ax3 is offline
Old 08-06-2005, 02:46 PM   #5 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
If u really want to remove codecs, open device manager, go to 'Sound, video and game controllers'. Open properties for th audio/video codecs, and in th box that opens, go to th 'Properties' tab. Click on th codec u want to remove and click 'Remove'.
Flickr!
Kl@w-24 is offline
Old 09-06-2005, 01:33 AM   #6 (permalink)
SABER RIDER
maverickrohan's Avatar
if uv installed codecs the ri8 way..........then u can delete them the right way by deletin them thru Add/Remove Programs...............
If installed via codec packs.........Uninstall the entire codec pack.......
Reinstalling codecs SCREWS up ur system so dont do it...........
U can download the latest K-Lite Codec Pack from www.free-codecs.com
it has 99% of the codecs ul ever need...........
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 09-06-2005, 03:30 PM   #7 (permalink)
Just Do It
Charley's Avatar
Even though I reinstalled the codecs it still doesnt play the files.
Charley is offline
Old 10-06-2005, 12:48 AM   #8 (permalink)
SABER RIDER
@achacko
be more elaborate........
reinstalled.........how?
does not play.........which files? why? what message does it give?
The right way is to UNINSTALL ALL CODECS...
n install them NICE n CLEAN
Old 21-06-2005, 04:27 PM   #9 (permalink)
ax3
ax3's Avatar
output sound is somewhot like ur walkman being played by an almost dead battery ...
tried uninstalling klite codecs & re-installing didn`t worked at all ...
whot should i do ???
... W H O T ...
ax3 is offline
Old 21-06-2005, 04:54 PM   #10 (permalink)
Stay away from codec packs. Try FFDShow.
-Keith
Keith Sebastian is offline
Old 21-06-2005, 11:38 PM   #11 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
-Keith
Wat is ffd show,
asking bcoz, wen i played a video file(cinepak codec), .. it didnt work,
n a icon appeared in system bar, when i move the cursur it reads ffd show.
I didnt understand,
n did the basic thing ... unistalled the codec pack, n reinstalled it.
Now the problem is solved, n the file plays fine.
But want to know why it happened?
rollcage is offline
Old 22-06-2005, 11:27 AM   #12 (permalink)
ax3
ax3's Avatar
hey in my case uninstalling & reinstalling again doesn`t help ...
whot 2 do ???
... W H O T ...
ax3 is offline
