FXP to FXP is what you are trying to do. Unfortunately there is no sure way to do this. Some servers allow you to fxp from one location to the other and others don't. I would say try your luck. Its quite simple to do. Like the others suggested use an ftp client. Smart FTP is a good client and its free too.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
