Old 07-06-2005, 10:08 PM   #1 (permalink)
Default BLACK SCREEN MESSAGE
WHEN I SWITCH ON MY COMP
AT THE BOOT UP SCREEN WHERE IT SHOWS THE INFO ABT MY COMPS PERIPHERALS THE COMP SHOWS ME FOLL MESS
PRIMARY IDE CHANNEL NO 80 CONDUCTER CABLE INSTALLED
CMOS CHECK SUM ERROR -DEFAULTS LOADED
AFTER WHICH IT ASKS TO PRESS F1 TO CONTINUE
AFTER PRESSING F1 EVERYTHING IS NORMAL.
WHEN THINGS GO WILD CYBO GET WILDER
LINUX ROCKS
WIND SUCKS
its still sucking
cyboincomp is offline
Old 07-06-2005, 11:36 PM   #2 (permalink)
anomit's Avatar
Now-a-days all HDDs come with 80-pin IDE connector cables. It seems you dont have one. Ask ur dealer for one or buy it.
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 08-06-2005, 12:11 AM   #3 (permalink)
aadipa's Avatar
Seems a problem with your BIOS.
Check the Mobo battery if it is working.... try changing it and check if the problem persists
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 08-06-2005, 11:24 AM   #4 (permalink)
l33t n00b!
Nimda's Avatar
Changing the mobo battery should fix the problem. Here's a link to help you out: http://www.rlrouse.com/computer-loses-time.html
Nimda is offline
