Old 07-06-2005, 09:40 PM   #1 (permalink)
Location: heaven doesn't want me and hell's afraid i'll take over
Default how to connect a...
hi
i have a laptop and a comp and would like to connect them through lan.how do i do this??the os on both the comps is win xp.i tried once and couldn't get it.
sandeeprao is offline
Old 07-06-2005, 09:59 PM   #2 (permalink)
1) open thinkdigit.com/forum ( which u already have by now )
2) click on tutorials section
3) search for digen's post on how to connect a LAN
4) when u have problems post in QnA section with specifics
so what problem are u having ?
No Mercy, No Limits.
theraven is offline
Old 08-06-2005, 12:19 AM   #3 (permalink)
firstly the question belongs to q&n section and
secondly search before posting
Happy Computing :lol:
krishnathelord is offline
Old 08-06-2005, 11:31 AM   #4 (permalink)
sorry guys, thnks anyway
Old 08-06-2005, 01:38 PM   #5 (permalink)
sorry for what ?
post ur problem here dude
what is the prob ur gettin while connecting ?
theraven is offline
Old 08-06-2005, 01:47 PM   #6 (permalink)
when i try to connect them togethere i get a mssg on the desktop pc that the lan hardware is disconnected, but i can connect to the net.i use a broadband connection.so that means that the ethernet card is connected isin't it
Old 08-06-2005, 02:34 PM   #7 (permalink)
Mr. S Nova
supernova's Avatar
check your cable. i hope you are using a cross cable for direct computer connection.
Knock Knock. Who's there? Opportunity. Can't be, opportunity knocks only once...
supernova is offline
Old 08-06-2005, 02:42 PM   #8 (permalink)
hey man i have the same config too but my lappy is running on winme and desktop is winxp / win98se / mandrakelinux 10.1 . i have used a cross cable, but i have one silly doubt y'day. I have a tata indico walky, and it has a data cable with one RJ45 jack at one end and a serial port the other end. so can i connect the serial port end to my pc and RJ45 end to my lappy to do data transfer ? which protocol shoul i use ? pls advise .....
Rajeev V Nair
premrajeev is offline
Old 08-06-2005, 07:53 PM   #9 (permalink)
in xp go to control panel click phones and modems
then add one
select dont detect
then select communication cable between two computers
then ok ok ok
btw the conection connection could be slow
