Old 07-06-2005, 08:49 PM   #1 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default error on startup
hello again.
this is the most wierdest error I have faced. I get an error stating
" an error occured in .exe file " during startup. the error doesnt specify the name of the file. So I cannot diable it from startup. please help.
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 07-06-2005, 09:13 PM   #2 (permalink)
expertno.1's Avatar
is ther any problem faced by u after that ?
expertno.1 is offline
Old 07-06-2005, 09:17 PM   #3 (permalink)
vandit's Avatar
Default reply
Not actually but I want to get rid of that !@#$%. from my startup.
vandit is offline
Old 07-06-2005, 09:29 PM   #4 (permalink)
l33t n00b!
Nimda's Avatar
Start -> Run and type msconfig -> Ok.
Now goto the startup tab and disable all items. Restart. The error shouldn't crop up this time.
Now go back to msconfig, and enable the programs u disabled one-by-one, restarting afte each change. You should be able to catch the program causing the error.
Nimda is offline
Old 07-06-2005, 09:31 PM   #5 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Click [Start]>[Run]>'msconfig. In th startup tab, disable th items which u r unaware of. Do a thorough virus scan with updated defs, and maybe a scan for spyware as well. (Just a hunch, not quite sure) :roll:
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
