Old 07-06-2005, 07:58 PM   #1 (permalink)
Default System Automaticall Restarts-Please help
Please help me.
I'm using Windows XP. Even after installing a fresh copy of XP after formating, I frequently get error like LSA export version crashed. The system will shutdown in 1 min. And then the timer starts.
I dont understand why it should come even after installing a fresh copy of windows.
Please help.
feelfree2mailme is offline
Old 07-06-2005, 08:05 PM   #2 (permalink)
You seem to have been infected by some virus/worm. Can you do a virus check?
paraman is offline
Old 07-06-2005, 08:08 PM   #3 (permalink)
l33t n00b!
Nimda's Avatar
Yet another Sasser problem. Visit:
http://www.pcreview.co.uk/forums/thread-105635.php
Nimda is offline
Old 07-06-2005, 09:18 PM   #4 (permalink)
Fresh Stock Since 2005
Make sure that you have installed latest security updates............. Man do a virus check and stay up-2-date
http://www.khattam.info
khattam_ is offline
Old 07-06-2005, 11:49 PM   #5 (permalink)
Default I've AVG and it's updated
I've AVG and it's updated and yet I'm facing the problem.
Thanks for the link Nimda
Old 07-06-2005, 11:50 PM   #6 (permalink)
anomit's Avatar
Check if any file like Isasss.exe is running in Win Task Manager. If yes,
Download the Symantec Removal Tool for W32.Sasser from here
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 08-06-2005, 03:16 AM   #7 (permalink)
The Hardware Labs
mohit's Avatar
better upgrade to service pack 2 after u remove the worm ... or still better do a complete reinstall and patch windows xp with sp2 . u will be free from such annoyances and your pc will be far more secure.
mohit is offline
Old 08-06-2005, 10:56 AM   #8 (permalink)
l33t n00b!
Nimda's Avatar
Oh and after removing the worm, make sure you install a good firewall if you don't want to get infected again within 10 minutes. I recommend ZoneAlarm.
Zonealarm: http://www.zonelabs.com
Nimda is offline
Old 08-06-2005, 12:32 PM   #9 (permalink)
Default Still cant
Thankyou guys for the support.
I'm still working on it though.
The symantec sasser cleaner didnt show any sasser worm.
I also get a "Generic Host process for win32 services"
and the system starts the shutdown countdown.
I formated c:\ and re-installed 2 times but I think the worm is sitting is D:\ which I cant afford to format.
Any ideas guys?
Old 08-06-2005, 01:58 PM   #10 (permalink)
Do you have SP2 installed or not?
paraman is offline
Old 08-06-2005, 02:41 PM   #11 (permalink)
club_pranay's Avatar
smells like MS blaster worm!!!... pls search the forum to find a way to get rid of it.. best way out...get SP2
or go here...norton support
happy worm hunting
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 08-06-2005, 04:56 PM   #12 (permalink)
Default Still no Luck.
Sorry to bother u guys again.
I get both the error messages. lsass and Generic Host process for win32 services. And then the timer starts.
Does that mean i've both the sasser and MS Blaster virus?
I do not have SP2 installed yet. Will installing SP2 at this stage help?
Come on guys, u r the genius', tell me what to do?
Old 08-06-2005, 06:54 PM   #13 (permalink)
I've run the sasser and blaster removal utility and yet it still shows that annoying message.
Please help.
Old 08-06-2005, 08:59 PM   #14 (permalink)
QA Juggler
saROMan's Avatar
well bud plz see This for Generic Host process for win32 services error ..and see if it helps..and see this and No. 85485-85488 Here for LSA export version crash..also its advised to install Sp2 ASAP ..for greater protection against such threats in the future....also d/l Hijack this ..and post ur Log file for better rectification....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 08-06-2005, 10:45 PM   #15 (permalink)
well i cant say how to get rid of that problem but you can do one thing go to run and just type "shutdown -a" to abort the countdown...in this way at least it will not restart.....could be handy till u find a solution for it...
abhinavchadda is offline
Old 09-06-2005, 01:06 AM   #16 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Umm First of all you should install a Firewall so that you dont get infected again ..
Yes installing SP2 will cure you of both the problems .. Go for it..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 09-06-2005, 06:05 AM   #17 (permalink)
Default Re: I've AVG and it's updated
Man that is not a very good antivirus.......
even if it detects viruses, it will be unable to remove it......
Try Avast, if you want a good free AV
khattam_ is offline
Old 09-06-2005, 10:12 AM   #18 (permalink)
expertno.1's Avatar
well Avast pro rocks
i recommend it higly
expertno.1 is offline
Old 09-06-2005, 07:28 PM   #19 (permalink)
Default Thanks
Thanks everyone of u.
I installed SP2 and Autopatcher from Digit and so far the PC is working fine.
All ur suggestions were valuable.
Thanks again.
