First of all try removing all the fancy themes and stuff. Don't know whether that's longhorn trans. pack, never used it. Anyway remove it and see if the prob. is solved.
Download Tweak-UI for Windows XP and install it. Then run it and in th left pane, open 'Explorer' options and click on 'Thumbnails' under it. Set th size of thumbnails in th right pane.
