Originally Posted by coolpepe
I have a Celeron 566MHZ processor, with 128 mb RAM installed on AZZA 810DTC MotherBoard. My problem is that my system shows only half of the ram i.e. 64mb. Can anyone kindly suggest me a solution.
Start by updating the BIOS.
www.azza.com.tw seems to be defunct. So, good luck finding any updates.
Try updating the chipset drivers here -
http://www.viaarena.com/default.aspx?PageID=2&Type=1
I think you have VIA P4X266 chipset on that board. Just a guess though. If yes, download VIA Hyperion 4in1 drivers.
If you're using 2x64mb modules, try switching slots.
-Keith
