Old 27-02-2009, 12:43 AM   #1 (permalink)
gsmsikar's Avatar
Default which ram conf is better ?
i am assembling a PC with ASUS M3A78-EM motherboard and
AMD Phenom X4 Phenom X4 9650 Quad-Core processor
i am using 1 x 2GB Kingston Ram ///
do i use 2 x 1GB ram or i can use 1 x 2GB ram module , which configuration is better ?
does dual channel works without using 2 ram modules ?
whose speed will be better ?
gsmsikar is offline
Old 27-02-2009, 11:48 AM   #2 (permalink)
Cool Buddy's Avatar
Default Re: which ram conf is better ?
dual channel only works if you have 2 modules, but doesn't really give a noticeable performance boost. so you can save the money if you like by using one 2GB module. if you are buying a graphics card then yu can do so all the more.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
xorg.conf for NVIDIA Faun Open Source 2 22-11-2008 06:33 AM
Best Pc Conf . in PC gapchoo009 Hardware Q&A 1 03-03-2008 12:48 PM
Looking for Perfect Conf. for Core 2 Sukhdeep Singh Hardware Q&A 16 12-10-2006 02:55 PM
How to Edit GRand Unified Bootloader.conf [GRUB.conf] whistler Software Q&A 5 11-10-2004 02:31 AM
