Rather than certification I would suggest doing course NCST by CDAC...
If you are from mumbai then you should do it from Juhu branch..
They teach you little bit of everything you mentioned in your post and everything is of advanced level, they expect you to know before joining...so you should be smart enough....
to get addmission there, you should score more than 95 percentile in their entrance test...
so if you get into that course and score good marks then def. you will get very good job...
you can checkout more info on that course here
http://ncst.ernet.in
2nd thing, if you just want to do certification and interested in programming then Java is the thing...
It is damn hot today in the market, people get salary from 35,000 - 50,000 a month if you know Java very well...
ASP.net is also in very good demand these days....
Deep
