Old 07-06-2005, 01:06 AM   #1 (permalink)
Default STSTEM WONT ACTUALLY SHUT DOWN (I AINT NO NOOB)
well i got win 98se and win xp pro on my old, lean system. the thing is that the system doesn't shut down when i try to make it so. the processor fan
keeps moving, hdd LED is on and the sound from the hdd is as if it's getting used . well it's driving me nuts ever since i came back home this summer.
my lil sis must've messed something up !!.
any bright ideas? i tried messing around with advanced power mgmt and all that, tried the bios, reset it once, even flashed it. everything with the software. now what could be the prob??
:roll: :roll:
maxguddu is offline
Old 07-06-2005, 01:21 AM   #2 (permalink)
Re-install and Check MAN !!!
CHeers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 07-06-2005, 02:00 AM   #3 (permalink)
Biplav's Avatar
u got the windows cd???
just insert and boot with it.
there is a repair feature. use that u wont loose anything. just the histories and the start menu listing thats it.
try and tell me .
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 07-06-2005, 09:32 AM   #4 (permalink)
expertno.1's Avatar
well if repair feature doesn't solves the problem then the last option would be to reinstall the OS
and upgrade ur system
expertno.1 is offline
Old 07-06-2005, 10:22 AM   #5 (permalink)
arcticflare's Avatar
hey i've got the same prob. i 2 have win xp and win 98 and the sys doesn't shut down. what i do is let the entire shutdown process finish and thn press reset button on cabinet and the press the power button to switch it off. after system is started up later it gives no diskchecking which means pc was shut properly
arcticflare is offline
Old 07-06-2005, 10:55 AM   #6 (permalink)
hey,
do u have anything of symantec installed? I had the same problem once and I uninstalled Norton. Everythin worked fine after that.
I now use AVG 7.0 free edition...it doesnt eat up resources like norton and has given me no problems.
check it out.
anna_don is offline
Old 07-06-2005, 11:04 AM   #7 (permalink)
yup mate i have norton sys works 05 dat must be prob
Old 07-06-2005, 11:34 AM   #8 (permalink)
l33t n00b!
Nimda's Avatar
Reinstallation is recommended but you could try this first:
Creating a shutdown icon on the desktop and using it to shutdown the PC:
Right click on the desktop
Click [New] [Shortcut] to open the Create Shortcut Wizard
Type [shutdown -s -t 00] without the brackets.
Click [Next] and type a descriptive name of your choosing for the shortcut
Click [Finish]
If that doesn't work, time to reinstall!
Nimda is offline
