Old 07-06-2005, 12:50 AM   #1 (permalink)
mario_pant's Avatar
Default converting DVD movie to CD.........HELP!!!!
hey..... i recently bought this DVD with all 5 home alone movies on it.... it is a total of 7.09GB ..... so i wanna make a backup of it without loss of quality or aspect ratio..... and i want it in .avi or some other high compression format..... can someone please guide me thru the method or link me to it........ 1movie on the DVD currently is of approx. 1.6GB.... can i fit it in a single CD?
PS: i want it for computer viewing only.....but not want it to take much space (probably wanna fit it off in a disc)
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 07-06-2005, 02:06 AM   #2 (permalink)
SABER RIDER
maverickrohan's Avatar
here goes............
if u want 1 movie per CD........this is the way to do it...
1. Download K-Lite Codec Pack from www.free-codecs.com
2. Download #1DVD Ripper from http://www.dvdtox.com/
3. Install Both
4. In The K-Lite Codec Pack Tools u will c Nic's Bitrate calculator
5. Enter The lenght of the movie, the audio bitrate usually 128kbps...n the final desired size..ie 700MB
6. This will give u a bitrate for say 700kbps........but use 680kbps for VP62
7. Run #1DVD Ripper
8. Select the DVD ROM drive.....it will show u all the movies present on the DVD
9. You will have to rip each movie separately(even though batch mode is allowed as all will b different in length)
10. in properties....select output as orignal DVD res or something lower as otherwise ur per pixel quality reduces....
11. Enable Dolby Surround...select approprite frme rate, depending on PAL/NTSC DVD
12. Settings:
Default Volume = 6
De Interlace: Interplate
Split Mode: Infinite
Enable all the check boxes below
In Output:
Video Codec for avi: VP62
Configure: Enter calculated bitrate(eg 650)
Mode: Good Quality Fast Encoding
End Usage: VBR
Material: Progressive
Sharpness: 5
Max Keyframe: 120
Noise Reduction: 0
Auto Keyframe: Enabled
Advanced:
Adjust Quantizer: Min 4 to Max 40
Misc Settings:
Temporary Buffer: set it acc to amt of RAM u have set eg. 100MB
Special Optimization: FPU
Check: Use ASAPI to access DVD Drive
Size/Bitrate:
Audio Settings for avi:
Lame MP3: 128kbps
Other than that select the Subtitle, the audio channel: AC3 6 Channel/2 channel etc...
Audio Quality: High
......see the other stuff...iguess i hvnt missed out on nything
Most Importantly..............go thru the entire topic in my siggie..........its informative.........
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 07-06-2005, 02:09 AM   #3 (permalink)
SABER RIDER
oh yeah n repeat the process for the no. of movies u wanna rip.........happy ripping..........for other help....im watchin this topic........u can always ask........ 8)
Old 07-06-2005, 11:23 PM   #4 (permalink)
been here on the forum 4 a long time havnt u ?? my suggestion , plz search b4 u start a thread
n 4 ur query , get Dr Divx .open ur movie file int it 4 encoding . mention the output file size as 700mb . select encode . ur done
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 08-06-2005, 03:18 AM   #5 (permalink)
Biplav's Avatar
hey dont worry just get nero 6.6 and use it!
simple
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 09-06-2005, 11:48 AM   #6 (permalink)
CCIE# 20863
U cn use easyDivX. It has a clean wizard interface, n it is fast, offers direct CD burning with plugins...
Bugs can neither be created nor be removed from software by a developer. They can only be converted from one form to another. The total number of bugs in the software always remain constant.
theKonqueror is offline
