Old 06-06-2005, 10:31 PM   #1 (permalink)
Curious Guest's Avatar
Default BitDefender 8.0.201 Released
BitDefender Professional Plus 8.0.201 + Standard + Free
Antivirus. The mission of the AntiVirus module is to ensure detection and removal of all viruses in the wild. BitDefender Antivirus uses robust scan engines, certified by ICSA Labs, Virus Bulletin, Checkmark, Checkvir and TUV.
- Permanent Antivirus Protection
The new and improved BitDefender scanning engines will scan and disinfect infected files on access, minimizing data loss. Infected documents can now be recovered, instead of being deleted.
- Peer-2-Peer Applications Protection
Filters against viruses that spread via instant messaging and file sharing software applications.
- Innovative Behavior Blocking
Blocks malicious applications based on behavior analysis. The method ensures proactive protection against newborn viruses, Trojans, Internet worms and other potentially malicious codes. The file system, registry and Internet activity are constantly monitored.
- Full e-mail protection
The application runs on the POP3 protocol level, blocking any infected e-mail message, regardless of the e-mail client used (MS Exchange, MS Outlook, MS Outlook Express, Netscape, Eudora, Lotus Notes, Pegasus, The Bat, etc), without any additional configuration.
*****Firewall. The firewall module protects your data and your privacy by filtering the incoming and outgoing traffic, controlling cookies, blocking malicious scripts and "XXX-dialer" type programs.
- Internet Traffic Control
Define exactly which incoming or outgoing connections to permit/deny. Define rules regarding specific protocols, ports, applications and/or remote address.
- Enhanced Internet Application Control
Alerts the users about any application trying to access the Internet. You will be notified wether the applications demanding network access are trustworthy, so you can make informed decisions.
- Comprehensive Privacy Control
The firewall filters incoming and outgoing cookie type files, keeping your identity and preferences confidential when you're browsing the Internet.
- Active Content Control
Proactively block any potentially malicious application such as: ActiveX, Java Applets or Java Scripts type codes.
- Dial Control
A configurable anti-dialer prevents malicious applications from running up a huge telephone bill at your expense.
*****AntiSpam. Quite simply put, the BitDefender AntiSpam module deals with the problem of spam, so you don't have to.
- Self-learning Bayesian filter
The advanced, self-learning Bayesian filter lets you classify messages as "Spam" or "Ham", with a single click. The filter will learn after just a few iterations, and you'll find yourself having to make fewer and fewer decisions as time goes by. Each tag you assign will improve the filter's accuracy. Your filter sensitivity settings can be as high, or as low, as you like.
- Heuristic, URL, Whitelist/Blacklist and Charset filters
Four types of filters further refine your control over e-mail. The heuristic filter checks mail for characteristics of spam.The Whitelist/Blacklist filter will reject mail from known spammer addresses and let your friends' mail through, the URL filter blocks mail containing malicious links and the charset filter blocks mail written with “strange characters.
- Hassle-free
You'll only be notified of the arrival of legitimate messages. Spam will collect silently in your "Junk" folder, to be examined or discarded at your leisure.
- Compatible with any e-mail client
BitDefender AntiSpam works with all e-mail clients and can be configured from the BitDefender Management Console. Moreover it integrates directly with Outlook and Outlook Express allowing a smooth interaction with the AntiSpam filter through an intuitive and easy-to-use interface
*****Other features:
- Informed Decisions
Configuration wizards are at hand to step you through all the procedures you need to follow to secure your system..
- Fast, Free, Automatic Updates
Intelligent update of antivirus protection, without user intervention. Live Update can be performed from the network, over the Internet, directly or through a Proxy Server. The product is able to repair itself if necessary, by downloading the damaged or missing files from BitDefender servers. BitDefender license owners benefit from free virus definitions update and free product upgrades.
Download BitDefender 8 Professional Plus
http://www.bitdefender.com/bd/downlo...er_prof_v8.exe
Download BitDefender 8 Standart - 13.8 MB
http://www.bitdefender.com/bd/downlo...der_std_v8.exe
Download BitDefender Free Edition 7.2 - 8.91 MB
http://www.bitdefender.com/bd/downlo...ee_win_v72.exe
Downloads for other OS at Home Page
http://www.bitdefender.com/index.php
_____________________________________
THE HELL IS FULL SO I AM BACK WITH DIGIT.
Curious Guest is offline
Old 11-06-2005, 08:31 AM   #2 (permalink)
Distinguished Member
anandk's Avatar
i personally think bitdefender is one of the finest ....
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
