as you can get what my system info is.... from my signature
i m playing doom 3.
what ever i try....i just only get 60 fps.
even though i have turned off vsync....and my refresh rate is 75.
it doesnt matter i use single card or in sli mode.
lowest settings or ultra settings....lowest resolution or max resolution(1280x1024)....i only get 6o fps constant.
i m using xp with sp1a and directx9c.
my system info is in my signature
and also...my cards in sli mode fetch a score of 14800 in 3dmark 2003
at 1024x768 AA none AF none.sound tests were not supported.
is this score is good ????or i m low with the sli mode.
plz help.
