Old 06-06-2005, 07:56 PM   #1 (permalink)
Default recommendations for combo drive
i want to buy a cd writer/dvd combo drive, which one would u guys recommend? i have a p4 2.4 ghz, windows xp pc! with 512 mb ram!
--Whoa--
neo_anderson is offline
Old 06-06-2005, 09:24 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
It's better that u buy a DVD rom and CD writer seperately. There may be problem with lens later on and it's better to have two ROMs instead of one and it costs a 200-300rs more....
See:
DVD Rom drive = rs. 1400
CD writer = rs. 1250
Total = 2700rs. or so
Combo drive = Rs. 2500
For CD writer , get Lite-On 52327S or 5238S or Sony CD writer.
For DVD ROM get Lite-On 165/166
For Combo (in case u want only this) get Lite-On 5232K
And oh yeah search b4 u post.
http://www.thinkdigit.com/forum/view...ighlight=combo
drgrudge is offline
Old 06-06-2005, 10:09 PM   #3 (permalink)
u can get LG for combo, me using for two yrs, no probs yet.
Shwetanshu Srivastava
shwetanshu is offline
Old 06-06-2005, 11:50 PM   #4 (permalink)
SONY !!!
Cheers !!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 07-06-2005, 12:09 AM   #5 (permalink)
busyanuj's Avatar
my vote goes for Sony. It's the best out there.
But if you actually want to make your drives last long then go for a dvd-rom and a cd-writer separately instead of a combo drive.
busyanuj is offline
Old 07-06-2005, 02:53 AM   #6 (permalink)
The Hardware Labs
mohit's Avatar
man i am bored of the same old questions people ask ... dude go for a separate witer and dvd rom from sony/lite-on... but if u want to go for a combo then go for sony/lite-on ... i am using one .. and faced no probs. my office comp has a lg combo and it is hardly 2 months old and it doesnt read dvd's properly while my sony does and it is a year old ... avoid samsung and lg.
mohit is offline
Old 07-06-2005, 03:58 AM   #7 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
PIONEER
Is
Best.
rollcage is offline
Old 07-06-2005, 09:27 AM   #8 (permalink)
expertno.1's Avatar
well i will go with shwetanshu
i have also LG combo and no problem at all from the last 2 years and its cheaper than sony
well if u realy wanna go then Lite-on will satisfy your budget
expertno.1 is offline
Old 07-06-2005, 10:08 AM   #9 (permalink)
vishal_bhatia87
Posts: n/a
In my opinion, Go & buy lite-on.
Pros:
Cheap & Value for money
Better quality & life long
Nero 6 Express & Power DVD Bundled
Black & White Both colors available
Old 07-06-2005, 10:15 AM   #10 (permalink)
QA Juggler
saROMan's Avatar
well my vote for Sony ...using for last 6 Months Excellent quality..havnt faced any problem yet ....also Guess only Sony has a protective Cover for Lense..which increses its Durability....also u want Value for Money then go 4 Benq/Lite-on
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 07-06-2005, 11:41 AM   #11 (permalink)
l33t n00b!
Nimda's Avatar
I recommend Lite-On.
LG is good too but I've never used a combo drive from LG so I can't tell correctly. I only have a stand-alone LG writer.
Nimda is offline
Old 09-06-2005, 12:39 PM   #12 (permalink)
i think liteon is the best.
go for it
\"As soon as you trust yourself, you will know how to live.\"
- Goethe
bendre123 is offline
Old 09-06-2005, 12:46 PM   #13 (permalink)
I completely agrees with drgrudge
You should buy a seperate cd writer & dvd rom.
I have my friends using combo & they are having problems with it.
Techmastro is offline
Old 09-06-2005, 02:31 PM   #14 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default I agree...... to some extent.....
I dont fully agree with all of u.
having a combo is like cutting one wing of a bird.
considering the huge storage space that a DVD gives , I would suggest for all those buyers of combos to opt for a DVD writer with dual layer support instead. but given the choice between a combo and seperate drives I would agree for seperate writer and DVD rom..... 8)
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 09-06-2005, 03:59 PM   #15 (permalink)
Just Do It
Charley's Avatar
I agree that combo drives if problems arises will be a headache but my friends have Sony and have been using the drives without any prob till date..
Charley is offline
Old 09-06-2005, 04:09 PM   #16 (permalink)
ashisharya's Avatar
LG is the best!
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 09-06-2005, 09:55 PM   #17 (permalink)
q3_abhi's Avatar
Go 4 sony combo -east or west sony is the best
q3_abhi is offline
