Old 07-09-2004, 11:40 AM   #1 (permalink)
Maverick340's Avatar
Default Spywares and Their Fixes.........Spybot and Ad ware aint GOD
I have a spyware(looks like one)called NAUPOINT bar and it pops up evry time IE 6 opens up
really bugging me
ADWARE and SPYBOT arent helping ....
ANY ideas??
Maverick340 is offline
Old 07-09-2004, 11:54 AM   #2 (permalink)
adit_sen's Avatar
be more specific man,......like wat does it exactly do...when it pops up?? wat pops up???
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 07-09-2004, 11:57 AM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Go to Windows/Downloaded Program Files/ and view th properties of th Active-X controls installed. Delete th one whose properties list th source as www.naupoint.com. Start regedit and search for 'naupoint' and manually delete all entries related to it. Be sure to backup ur registry before attempting this.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 07-09-2004, 11:59 AM   #4 (permalink)
this is like a search bar...
it opens along with IE 6
like google toolbar!
You and Me forever be ...
PSpwned
Old 07-09-2004, 03:24 PM   #5 (permalink)
THANX kl@W
that trick worked!!!
thax a lot
PSpwned
Old 07-09-2004, 04:17 PM   #6 (permalink)
When spybot and adware dont work, you should post your HijackThis logfile.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 08-09-2004, 12:24 AM   #7 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Please post your HijackThis Logfile for better assesment of your problem.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 08-09-2004, 05:01 PM   #8 (permalink)
nipun_the_gr8
Posts: n/a
Hey Kl@w ! i am facin' a similar kinda prblm. whenever i search, a "Side Find" window opens which shows links related to wat i searched for. there's no entry to remove it in the add/remove programs. Wat shud i do ???????????
P.S. - whenever i run regedit and search thru internet explorer menu, i find some keys named SideFind.
Old 08-09-2004, 05:34 PM   #9 (permalink)
Do what I told above ...
Old 08-09-2004, 10:03 PM   #10 (permalink)
check if you have the updated definition files for your spyware removal apps
a wise man once said:
\"he who laughs last.........doesn\'t get the joke\".
shehan9999 is offline
Old 10-09-2004, 05:09 PM   #11 (permalink)
nipun_the_gr8
Posts: n/a
k...........thankx.................!!!!!!
Old 12-09-2004, 09:03 PM   #12 (permalink)
Always Fresh!
shri's Avatar
CWShredder.exe works if homepage is hijacked
BE YOURSELF :)
http://everythingoutthere.co.cc
shri is offline
Old 12-09-2004, 10:31 PM   #13 (permalink)
mariner's Avatar
ya cwshredder is a good one for browser hijackings
mariner is offline
