Old 06-06-2005, 04:32 PM   #1 (permalink)
Default 16 bit MS-dos Error solved - Anwser
thanx anna_don
\Worked fine and the ms-dos subsystem is up and running fine. DO you know how this problem was caused in the first place >>> ??
Thanks once again
If any one else has this problem try this out and Hope it works
Go to Windows subdirectory repair , ie C:\WINDOWS\repair , and just copy the .nt files , ie *.nt to the C:\WINDOWS\system32 directory. It should work out.
But jsut to be on the safe side , Does anyone know how this problem could be caused in the first place ??
Huzefa.
Huzefa is offline
Old 06-06-2005, 07:34 PM   #2 (permalink)
no sweat huzefa
and i've been wonderin y the problem occured in the first place too
ideas any1?
anna_don is offline
Old 06-06-2005, 07:50 PM   #3 (permalink)
expertno.1's Avatar
the problem might be caused to some incompatible software insatllations that made modification in the nt files
also some tweaks if u have done might be responsible for the error
any could be the problem?????
expertno.1 is offline
Old 07-06-2005, 10:51 AM   #4 (permalink)
l33t n00b!
Nimda's Avatar
This is a very common problem. The solution you gave is correct, but one important step is missing.
After copying the *.nt file to \System32, you have to make them read-only. Otherwise, the problem reappears again and again.
Nimda is offline
Old 07-06-2005, 03:03 PM   #5 (permalink)
GetUserTitle()
huzaifa b arab's Avatar
Yes, expertno.1 is right.
huzaifa b arab is offline
Old 07-06-2005, 10:27 PM   #6 (permalink)
been there
done that
search forum for solutions to the problem
thank you for the initiative tho
locking ......
No Mercy, No Limits.
theraven is offline
