Old 06-06-2005, 02:56 PM   #1 (permalink)
Default Blue tooth connection failsl
Friends I am unable to use BLUETOOTH in my PC. While loading bluetooth software some files like(1) Cab files wont be found(2)Connecting ports fails (3) PAN Connection never gets enabled. By the way which company bluetooth is of better quality and how much it costs?
prabhakarp@sancharnet.in is offline
Old 06-06-2005, 06:27 PM   #2 (permalink)
Just Do It
Charley's Avatar
Bluetooth ?? Do u mean head sets/dongles, etc? ?
Charley is offline
Old 07-06-2005, 10:36 AM   #3 (permalink)
pirates1323's Avatar
Hey I think reinstalling the software won't solve the prob... when first time I bought bluetooth dongle and can't even connect my phone to pc...
Clean installation would be better i.e format ur PC ... & then install it step by step carefully....
for better results use windows xp with no service packs.. but with all critical updates.. yes thts right
pirates1323 is offline
Old 07-06-2005, 11:33 AM   #4 (permalink)
busyanuj's Avatar
it's the other way round, bluetooth works best in Windows XP with Service Pack 2 installed.
busyanuj is offline
