Old 19-02-2009, 08:50 AM   #1 (permalink)
Self-Obsession
hittheswitch's Avatar
Talking Adding more hard drives ;)
I had a day off from work yesterday so i decided to assemble a desktop for myself. I had a whole lot of junk lying in the store room.
By the end of the i had a decent desktop with a 17" monitor (and wireless keyboard + mouse ). Now i'm facing a problem here. I assembled a desktop with an Intel 915 motherboard. It has 2 sata slots and allows one IDE cable. This way i can add 2 sata devices and two PATA. The situation is :
I have 3 IDE drives, one SATA HDD and 2 IDE DVD-Writers... I wanna attach all of them (I know i'm a little greedy ).
What i've done for now is that i have attached 2 IDE drives and a SATA HDD. I Installed XP by attaching the DVD-writer for some time. I know you guys can come up with a solution. I dont like both of my DVD writers and a HDD lyinh idle in my desktop.
Thanks in advance
I'm walking between mads,but whats the use i'm still the worst one.
hittheswitch is offline
Old 19-02-2009, 09:08 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Adding more hard drives ;)
^^ okay. There are IDE to SATA converters available in the market. This way you can attach one IDE drive to SATA port.
If you have free PCI slot, get PCI IDE extension card and to this you can add another two IDE drives.
it looks something like this: http://www.dealtime.com/xPO-Fanner-M...-2-eSATA-Ports
desiibond is offline
Old 19-02-2009, 09:12 AM   #3 (permalink)
get an IDE to SATA connecter : Comes for Rs. 500 each.
Faun is online now
Old 19-02-2009, 09:24 AM   #4 (permalink)
Self-Obsession
Thank you guys for your prompt replies.
Yep.. the PCI IDE card seems to be a nice solution. This way 'll be able to hook up the additonal HDD and DVD writer but there would be a DVD writer going to waste. Anyways, I can live with one DVD writer going to waste. But the problem is, I have two PCI slots and both of them are currently being use. One has a TV-tuner and the other has a WiFi controller ( nobody wonders how much stuff i had lying in my store room )...
The second solution is a SATA to IDE converter i believe... I'll look for it on the internet...
Old 19-02-2009, 01:18 PM   #5 (permalink)
AFK
thewisecrab's Avatar
Here is guide from TD forum member ChotoCheeta
http://www.chotocheeta.com/2007/10/2...usb-hard-disk/
I myself did the same (though I got "TAG" brand of convertors)
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 26-02-2009, 07:09 AM   #6 (permalink)
Self-Obsession
Problem Solved. Added a PCI card. All drives work now. Thank You guys
Appreciate it!
Old 26-02-2009, 08:05 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Most PCI IDE cards use x1 PCI slot (the tiny pci slot that is about 1/2 inch in length) and not the usual slots
Pls help me to access my hard drives bratsameer Software Q&A 8 21-04-2009 02:11 PM
Additional Hard drives pradeepbp Open Source 10 12-10-2007 01:21 PM
Hybrid Hard Drives DukeNukem Technology News 2 27-10-2006 09:19 PM
Samsung: 'Hybrid' Hard Drives ferrarif50 QnA (read only) 6 01-05-2005 07:34 PM
