Old 06-06-2005, 01:16 PM   #1 (permalink)
Default Shortcut icon
Hi,
A small arrow mark in a rectangle box appear in shortcut icons, how can I remove this, can anybody help about this.
aathif is offline
Old 06-06-2005, 01:23 PM   #2 (permalink)
expertno.1's Avatar
well bud thats shortcut mark and u canoot replace it untill u do some registry tweaks
well the forum gurus wil tell u more
expertno.1 is offline
Old 06-06-2005, 02:44 PM   #3 (permalink)
QA Juggler
saROMan's Avatar
get tweakUI/system mechanic/tweakXp etc....there u have option to remove the Shortcut icon..with out messing up the registry....my sugession get TweakUI...
See the illustration below...its really easy....
also TweakUi is 4 both 98/XP
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 06-06-2005, 09:46 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
download a good tweaking utility from www.download.com
try tweakxp pro, tune-up utilities, etc
itl help you remove the arrows, but offer u sevreal other tweaks too !
also visit sites like these :
http://www.greece.k12.ny.us/taylor/tips/index.html
http://www.kellys-korner-xp.com/xp_tweaks.htm
http://www.tipsdr.com/
have fun tweaking !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 06-06-2005, 10:09 PM   #5 (permalink)
Biplav's Avatar
Do you have System Mechanic???? It certainly is useful software. It has got many tweaks and one of them removing the shortcut icon. get it here
another very useful software is registry seeker. It is one of the free registry cleaner softwares available.Believe me it does great work and that too real fast .it has got a few tweaks and u can remove shorcut arrows with those little tweaks..get it here
else do this in the registry urself
Remove Shortcut Arrows
[HKEY_CLASSES_ROOT\lnkfile]
"IsShortcut"=-
Shortcuts without "Shortcut to.."
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer]
"link"=hex:00,00,00,00
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 06-06-2005, 10:30 PM   #6 (permalink)
TweakXP pro trial version is enough for wat U want ..
Just in case U want the messy registry thing! let me know!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 06-06-2005, 11:13 PM   #7 (permalink)
Use Tuneup Utilities 2004 To Remove it easily in one click
enjoy
bye
murali krishna b
Murali is offline
Old 06-06-2005, 11:17 PM   #8 (permalink)
Biplav's Avatar
simply add the ones or modify it in registry - no need of any external software.
Biplav is offline
Old 07-06-2005, 07:17 AM   #9 (permalink)
q3_abhi's Avatar
Go for system Mechanic 5, u will get many other tweaks including urs.
q3_abhi is offline
Old 07-06-2005, 07:21 AM   #10 (permalink)
Ignorance is BLISS !!
X-Setup Pro will be the BEST tool for tweaks such as this one and many more as well !
rajkumar_personal is offline
