Old 07-09-2004, 11:22 AM   #1 (permalink)
Default Looking for Config. for Graphics Purpose
I'm a Digital Artist, most of my work includes working on softwares like 3dsmax , Maya ,Combustion......
i'm looking for a good config around 40k to 45k, with a good processing power & a neat graphics card.i'm stuck up in the decision whether to go for P4 2.8 HT or AMD 64. please help me in making a decision. I have a config taken from a dealer.
 Intel D865GBF Original Motherboard with 800MHz & HT support [Intel] [5250]
Integrated Onboard Graphics, Sound & with AGP Slot
>>Intel  Pentiumâ„¢ 2.8 GHz CPU, 1MB cache, 800 MHz FSB [Box Pack] [8750]
>>512 MB DDR RAM [PC 400] [Transcend] [256MB X 2] [5500]
>>Black 80 GB SATA Hard Disk Drive [Samsung 7200RPM] [3500]
>>Black ATX Cabinet with SMPS with 300W [1325]
>>Black 17� Flat Color Monitor [Viewsonic E70F] [7950]
>>Black MM keyboard Black Scroll mouse [Logitech] [875]
>>Black 16X DVD Drive [Sony] [2050]
>>ASUS V9520 HT/128MB GF FX 5200 [9500]
it cost somewhere around 44k & its almost a 2 weeks old price. if any of u have a better config than this with the same cost than let me know.i'm looking for a good AMD 64 CPU Config... also give a contact no. of a genuine AMD dealer.
thanx in advance
No is always an option!
idisappear is offline
Old 07-09-2004, 01:21 PM   #2 (permalink)
dont go for an fx 5200 if u need this for graphical work
get atleast an ati 9600 pro for 8.5k
No Mercy, No Limits.
theraven is offline
Old 10-09-2004, 06:32 PM   #3 (permalink)
Yes. A better graphics card is what you want.
Simple things are to simple too understand.
Prashray is offline
Old 10-09-2004, 07:10 PM   #4 (permalink)
thanx to Theravan & Prashray.
What u guys think about the Processor, is it well enough to handle such applications in the long run, coz most of the applications are Processor demanding.
Wat is ur opinion for the AMD 64.
Old 10-09-2004, 08:55 PM   #5 (permalink)
AMD 64.
Prashray is offline
Old 10-09-2004, 10:40 PM   #6 (permalink)
Definitely AMD 64 as it beats most equivalent Intel processors.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 10-09-2004, 11:29 PM   #7 (permalink)
yup
but on a more negative note ... (like im feelin right now so dun mind)
nuthin lasts for ever
sighhhh
even the 64 bit processors will die someday
sighhhhh
hahaha ... nah just messing .. amd 64 is the way to go if u can afford it
cuz its gonna add a nice 8-10k to ur present config !!!
oooo .. one more thing
no point in going in for 1 sata drive
unless ofcourse u plan to upgrade
and as for now ... 2 ide drives in raid should be sufficient so u can save there .. not much tho
just lettin u know ur options
and ofcourse a cd writer has almost become a norm now .. so instead of a dvd drive go in for a combo drive
or a separate cd writer with
whichever one u prefer
theraven is offline
Old 11-09-2004, 10:05 AM   #8 (permalink)
thanx to u guys for the opinions.
But i searched the forums & somewhere the price of the AMD 64 2800+ was mentioned was 8K, & i.e. less than P4 HT 2.8Ghz 8.7K,.... not much..but still a difference.
wat about a combo of AMD 64 2800+ & ASUS K8V Mobo??????
Old 11-09-2004, 11:55 AM   #9 (permalink)
gxsaurav
Posts: n/a
GeForce & Radeons are not qualified to run Maya & 3Ds Max etc, however they will run all a bit slowly then Quadro & FireGL
I do animation, for my Video editiong work, I use Maya, My specs are
P4 3.06 GHz with HT
512 MB DDR 333, dual channel
865 GBF with Lan
FX5900XT with 18 MB DDR2 RAM, Gigabyte
U should go for atleast a AMD64 3000+ for anything animation, along with 1 GB RAM, 80 GB is enough for low level animation but if U R in hardcore unlike me then go for 120 GB & make a dedicated swap partition of 1 GB
U might wanna consider taking my system as a base to make your system
Old 11-09-2004, 12:14 PM   #10 (permalink)
Yep if gamings not ur priority..........then go for Quadro/ FireGL cards.
Old 11-09-2004, 12:28 PM   #11 (permalink)
how much will Quadro/FireGL cards cost me????????
Specify some model nos. for reference.
Old 11-09-2004, 02:15 PM   #12 (permalink)
gxsaurav
Posts: n/a
Not too sure about now, but I wanted to buy a Quadro FX 4000 AGP8X before buying my FX5900XT, the cost was a stagering 1,25,000, but then again it's a pro level card, big corporation & animators can buy it
U R better off with a GeForce 6800GT from Gigabyte for Rs 32,000 at most or get a FX5900 non Ultra for Rs 20k
Old 13-09-2004, 11:19 AM   #13 (permalink)
FX5900 & other Geforce would really burn a deep nole in my pocket...
i'm looking for a good graphic card within 10k to 15K.
plz suggest.
Old 13-09-2004, 12:55 PM   #14 (permalink)
gxsaurav
Posts: n/a
told U na, FX5900XT for 16k
Old 13-09-2004, 01:24 PM   #15 (permalink)
Radeon 9800pro for 14.8k. best performance/price ratio.
Old 13-09-2004, 02:09 PM   #16 (permalink)
i second the radeon 9800 pro
theraven is offline
Old 13-09-2004, 02:43 PM   #17 (permalink)
Thanx guys
Radeon 9800pro is best bet for me in terms of Price/Perfrmance.The only confusion left is whether to opt for AMD 64 & ASUS K8V mobo or P4 2.8HT & 865GBF mobo....
Anybody there plz help me yaar..........
Old 13-09-2004, 03:07 PM   #18 (permalink)
gxsaurav
Posts: n/a
amd 64 3000+ with ASUS K8V
if that is not available then go for 2.8HT with 865GBF, rewmember 2.8 HT will beat 2800+ when it comes to graphics, however 2.8HT will be beaten if U have a 3000+
Old 13-09-2004, 06:35 PM   #19 (permalink)
i second that as well !!
AMD's are killer !!
theraven is offline
Old 15-09-2004, 11:22 AM   #20 (permalink)
This is the final Config. Which i found is better & refined
>>Processor : Intel Pentium 4 LGA 775 3.0GHz HT,800 MHz FSB, 1 MB Cache
>>Motherboard : Intel D915GAV, 915 chipset, 800MHz FSB , Dual DDR Ram , Intel Media Accelarator Pro 900, PCI Extreme Graphics , Intel High Definition Audio
>>HDD:Samsung 120 GB Hard Drive, 7200 rpm SATA HDD
>>Samsung combo Drive
>>Ram:Transcend DDR 400MHz,256 x 2
>>Monitor:Vewsonic E71 17"
>>Graphics Card:ATi Radeon 9800pro
>>ATX Cabinet :400W
>>Keyboard : Logitech Black Keyboard
>>Mouse : Logitech Optical Mouse
What guys have to say about it????Howz it
Old 15-09-2004, 01:49 PM   #21 (permalink)
u cant go for the 9800 pro if u get the 915 chipset
its an agp8x card. .. the mobo supports pci-E
theraven is offline
Old 17-09-2004, 10:46 AM   #22 (permalink)
So what to do???????? is there any good PCI-Express card available or should i go for 865GBF Mobo.
There is a confusion again in my mind.
The place where i work i have a AMD Athlon XP 2800+ with 512 MB DDR RAM, yesterday i had a file to render in Adobe Aftereffects, for a Resolution of 720 x 612 it took a 2hrs 38min. & the same thing i put it on a Dual Xeon Processor with 2GB of RAM with a resolution of 2048 x 1742 it rendered it in a whopping 2hrs 13min.
this means Xeon is really fast.The price difference of the Xeon & P4 3.0 HT is somwhere around 5K to 7K, so is it worth to go for a xeon based machine.
Wat r ur suggestions on this....
Old 17-09-2004, 02:48 PM   #23 (permalink)
pciE cards are available
x600 for 17k .. but its not as good as the 9800 pro ... cuz its supposed to compete with the 9600
like i said go for an amd...
for this newer intel chipset u have to wait till next year sets in .. and we see the technologies settling in
and no u cant upgrade to a xeon machine .. cuz effectively all ur costs will go up.. even the mobo
xeon are server machines .. specially dual processors ...
those ARE NOT meant for the comsumer market yet ...
theraven is offline
Old 18-09-2004, 06:33 PM   #24 (permalink)
GO FOR ASUS SK8N AND A AMD64FX
Writankar panja is offline
Old 20-09-2004, 12:20 PM   #25 (permalink)
OK Guys thanx for the Suggestions, this is the outcome.......
>>Processor : AMD64 2800+
>>Motherboard : ASUS SK8N (does it supports AMD64) or K8N or K8V????????/
>>Samsung combo Drive
>>ATX Cabinet :400W
i should settle down with this....i guess.....but still suggestions r always welcome.
since u guys have suggested this now do me a one more favour,let me know the contact no. of a good AMD Dealer out there, i'm thinking to get it before the end of this month or may be the start of the next month.
Old 26-09-2004, 05:25 PM   #26 (permalink)
The SK8N is for socket 940, go for K8V. The K8N is meant for semprons i think.
Old 29-09-2004, 08:57 AM   #27 (permalink)
Regarding the Radeon 9800pro which make is better??????
Old 29-09-2004, 10:05 AM   #28 (permalink)
gxsaurav
Posts: n/a
Gigabyte is something I can recomend without any doubt, I had a Radeon 9600 Pro, but now have a FX5900XT, more compatible then Radeons & drivers are also lower in size, besides feature wise it is batter then Radeon 9800 Pro
Old 29-09-2004, 02:37 PM   #29 (permalink)
Giagbyte is good so is Hercules, while Club3d has a good price to performance ratio. Stay away frm powercolor !
Old 29-09-2004, 04:50 PM   #30 (permalink)
well atleast in india powercolors are pretty bad ...
the ones abroad get rated quite well SURPRISINGLY !!
id suggest the same .. but in this order
1) HERCULES
2) GIGABYTE
3) CLUB3d
thats cuz one of the hercules 9800 pros had a blue LED fan on it
theraven is offline
