Old 16-02-2009, 06:49 PM   #1 (permalink)
rajwansh2003's Avatar
Default Help about ip address
When ever i am downloading from rapidshare it say your IP address is already downloading file.can any one help me !!!!
I am using BSNL EVDO 2.4 mbps.
Anupam
rajwansh2003 is offline
Old 16-02-2009, 10:11 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: Help about ip address
If you are free user, you can download only one file at a time. If you experiencing problems inspite of this, then you may be either sharing IP address with some other user who is downloading from rapidshare. You can try disconnecting and connecting again to see if that works.
गीक होना माँगता
victor_rambo is offline
Old 16-02-2009, 10:18 PM   #3 (permalink)
Cool G5's Avatar
Just disconnect & reconnect, you should be able to download the next file.
Cool G5 is offline
Old 17-02-2009, 12:29 AM   #4 (permalink)
provided he has dynamic IP
ayuboy is offline
Old 17-02-2009, 12:33 AM   #5 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
No guarantee these will work and there is no proper solution. Either buy a rapidshare account if you are a regular downloader... some 600 RS for a month and get super download speed.. or wait for hrs if you have a free account.. also remember if you start downloading a file and stop in between RS thinks you are still downloading.
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 17-02-2009, 07:17 AM   #6 (permalink)
6x6
half way there
6x6's Avatar
in gprs all the users of a state share same ip (from small range say 16), so everytime you get the ip from these 16 ips. may be evdo uses same funda. you can check your ip at showmyip.com
6x6 is offline
Old 17-02-2009, 10:12 AM   #7 (permalink)
restart does not work any help without cash paypal
Anupam
Old 17-02-2009, 11:15 AM   #8 (permalink)
Cool G5's Avatar
I use Airtel GPRS.
Disconnecting & Reconnecting works for me everytime.
In case of a static IP, it won't work.
Cool G5 is offline
Old 17-02-2009, 02:30 PM   #9 (permalink)
In BSNL Evdo connection you are given shared IP..so if many people are connected to same tower their ip will be detected as same..thats the biggest broblem with bsnl evdo/tata photan..
foruamit2004 is offline
IP Address Ron QnA (read only) 8 10-11-2008 07:36 PM
IP address amitsaudy QnA (read only) 6 02-04-2008 07:49 AM
How to remove 'Address' from the Address Bar in Explorer Toolbar? Samystic Software Q&A 12 31-03-2007 12:28 AM
ip address Tushar.bar Software Q&A 8 27-09-2006 12:41 PM
MAC ADDRESS champ_rock QnA (read only) 9 05-11-2005 10:53 AM
