Old 06-06-2005, 12:49 AM   #1 (permalink)
Default (SDRAM or DDR) advice me plzzz
hi,
People i got assembled my computer last year's summer .. & i paid for a DDR 512 MB RAM .. now when I checked it using CPU-Z.. i found its SDRAM 512 MB (133 MHz)
Now shd I ask from my dealer abt this ... Shd i get it exchanged ... plzz tell me!! Although my comp is working just fine! .. no probs at all!
Thanks! in advance!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 06-06-2005, 01:00 AM   #2 (permalink)
mariner's Avatar
go and ask ur dealer for an exchange. ddr rams are much faster than the sd rams.even though ur comp is working fine u will notice the difference when u install ddr ram.
mariner is offline
Old 06-06-2005, 10:57 AM   #3 (permalink)
hey mayb ur board did not support it so he had to give u SDram !!!
CHeers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 06-06-2005, 12:28 PM   #4 (permalink)
anomit's Avatar
Yeah man, cahnge it. DDR RAMs are available in 266 and 400 MHz i.e. twice and thrice the speed of SDRAM.
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 06-06-2005, 12:56 PM   #5 (permalink)
expertno.1's Avatar
and DDRSDRAM anre more sasta than the SDRAM's
expertno.1 is offline
Old 06-06-2005, 01:24 PM   #6 (permalink)
if ur mobo supports ddr ram then that stick is definitely DDR ram
since sd ram wont fit in DDR ram slot
sdram at 133 mhz into Dual Data Rate = 266 Mhz ddr ram
so i see no problem here
u got what u paid for
No Mercy, No Limits.
theraven is offline
Old 06-06-2005, 02:08 PM   #7 (permalink)
Attention:
Yes u have to replace for a ddr ram. simply cos they r better. also u need to check on clockspeed of ddr rams. 133 mhz which u have currently r outdated ones. memories have to be big (512mb) and fast too (400 mhz) to perform the best. n u can do dat easily cos the price diff is very very less. say some 200. u can get a ddr514/400 at just 2400 rs.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 06-06-2005, 03:52 PM   #8 (permalink)
Well dude looks like he cheayed u with this one, if he really said DDR ram, then it must be a different Motherboard, as old motherboards don't support DDR ram, & new DDR-Ram ones don't support SD-Ram, speak to him & ask him about it.
COLDROCK is offline
Old 06-06-2005, 09:04 PM   #9 (permalink)
my MOBO is intel D845HV ... does it support DDR or not! can neone explain this to me!
& theraven I see it through CPU-Z .. if it can also be incorrect abt wat kind of RAM is it!!
& thanks! a million to U all for ur valuable contributions but plzz help me more on this!
Old 07-06-2005, 01:13 AM   #10 (permalink)
266 and 333 mhz
ddr ram is Double Data Rate SDRAM
so yes it shows up as SDRAM and speed as half of what it should be
that is 133
so 133*2 ( for double data rate) = 266 mhz
hence u have 266 mhz DDRSDRAM
theraven is offline
Old 07-06-2005, 10:17 AM   #11 (permalink)
one more question : CPU-Z on my computer showed tht my RAM is SDRAM ... but when i run it on my frd's COMP ... it said DDR SDRAM .. Y can this be ?? bcz SDRAM wont fit in a DDR ..
& last sumer i paid 4100 bucks for my RAM .. is tht cost fine or is it the cost for 400 MHz (or 333 MHz) DDR ??
also, tell me will the performance be affected too much by replacing a 266 MHz .. to 400 MHz or 333 MHz .. bcz my system is working just fine! no probs at all
plzz answer these queries too! & thanks a million for ur earlier response!!
Old 07-06-2005, 11:44 AM   #12 (permalink)
l33t n00b!
Nimda's Avatar
Well, if you push it too hard, SD might fit into a DDR slot
Regarding the speed of DDR, you should go for that clock frequency which matches the FSB of your processor. For eg, if you have an Athlon XP 1800+, DDR 266Mhz would be best suited for it as the XP 1800 has an FSB of 266Mhz.
Nimda is offline
Old 07-06-2005, 12:57 PM   #13 (permalink)
I have Intel Pentium 4 >> 2.0 GHz
Old 07-06-2005, 01:09 PM   #14 (permalink)
ashisharya's Avatar
go for DDR RAM
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 07-06-2005, 01:14 PM   #15 (permalink)
l33t n00b!
Nimda's Avatar
Originally Posted by ashisharya
go for DDR RAM
Duh. What's that supposed to mean? Wasn't he going for DDR in the first place?
Nimda is offline
Old 07-06-2005, 02:01 PM   #16 (permalink)
Default Re: (SDRAM or DDR) advice me plzzz
Originally Posted by yehmeriidhain
hi,
Thanks! in advance!
hmm well what do you know .... you've been ripped off (and the brendonface also shows that..qurik). get hold of the dealers throat ask for an exchange and next time be careful
sagsall4u is offline
Old 07-06-2005, 04:02 PM   #17 (permalink)
sagsall4u well there is nothing! ..... like ripping over here! i checked my MOBO box cover today & it says tht it supports .. 133 MHz DDR SDRAM & i have tht only .. so i did say U swayed into emotions too much here! ! ...
Thanks! a lot fellas...
Old 07-06-2005, 10:29 PM   #18 (permalink)
sigh i just replied to ur pm
forgot what i typed there
plz follow it
theraven is offline
Old 08-06-2005, 09:53 PM   #19 (permalink)
Default is u say soo
gr8 i'm happy u well didnt get ripped off.
and man where was my emotions showing ... hat too over a ram that u bought .. LOLOL har har
