Old 05-06-2005, 10:45 PM   #1 (permalink)
Location: heaven doesn't want me and hell's afraid i'll take over
Default buying a new comp....need help
i'm gonna buy a new comp.and my budget is 40k.so can someone suggest a good config??i don't need a graphic card right now so could u suggest a good mobo with a decent onboard video??i want ONLY an AMD pross and at least 1 gb of ram.. so plz help me.give me a good config and i'll check out the prices and get back to u guys.
by the way i stay in chennai and plan to buy it from ritchie street.
thnks a mill
sandeeprao is offline
Old 05-06-2005, 11:14 PM   #2 (permalink)
New comp. Config. 40k. ---- Just use these in the forums search. You'll definitely get loads of results.
Here's one -
http://www.thinkdigit.com/forum/viewtopic.php?t=22105
Keith
Keith Sebastian is offline
Old 05-06-2005, 11:29 PM   #3 (permalink)
The Hardware Labs
mohit's Avatar
amd athlon 3000+ (939 pin)
msi rs480 m2 motherboard
512*2 DDR 400 Mhz RAM (Kingston/Corsair/Zion)
Samsung Magic bright 2 17"
Ibox cabinet with min.350W smps (get antec if your budget permits u)
Logitech/microsoft mm keyboard/optical mouse
80 Gb seagate SATA N.C.Q
2.1 speakers (creative/altec lansing)
Go for a liteon optical drive whether it is a writer or a rom.
mohit is offline
Old 06-06-2005, 11:39 AM   #4 (permalink)
i asked the guy for the price of this config
he said for 40k he could give me a 160 gb segate hdd and 4.1 creative speakers + the config u gave me.
so is this good??
he says that the parts that he supplies are all original .,
Old 06-06-2005, 11:40 AM   #5 (permalink)
and a sony dual layer dvd writer.
Old 06-06-2005, 02:23 PM   #6 (permalink)
The Hardware Labs
mohit's Avatar
u r getting a real good deal then ... make sure you buy a sata n.c.q 160gb from seagate though .. and is he giving the sony dvd-rw also in 40k ?? man this is a very good bargain then... go for it but just make sure you get all original and new stuff. make sure u see a box packed processor and motherboard before he installs them and get the system assembled in front of your eyes only. also confirm the 5 years warranty of the hard disc by verifying its serial no on the seagate website. you can do the same for the kingston ram.
mohit is offline
