Old 05-06-2005, 05:55 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default pls help. connectivity problem
since today, dont know how or what happened. but in system tray, i started get getting an icon of two pc's (network) with a YELLOW exclamation mark, in a triangle. when i move my cursor on it, it shows
local area connection
speed : 100 mbps
Status:limited or no connectivity.
when i rt click, and click on Repair, it says:
windows could not finish repairing the problem, bcoz the following action cannot be completed :
Renewing your IP address.
for further assisstance, contact the person manages your metwork.
As a result, my internet speed is presently barely a few kbps !
mine is a stand-alone, single-user, home pc, usong winxp/sp2.
i use dataone broadband.
any1 know what hapnd ? is it some os/xp problem? pls help.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 05-06-2005, 07:51 PM   #2 (permalink)
prolly somethin wrong wid ur ip settings....
call ur isp and ask dem wat ur ip address is......
den.....put dat in ur tcp ip settings
Be AfrAiD oF DaTA LosS........
bE vErY aFrAid!!!!!!!
irradiated_chicken is offline
Old 05-06-2005, 07:54 PM   #3 (permalink)
QA Juggler
saROMan's Avatar
well bud u get this prob mostly after a new installation.....also u get the IP error coz Dataone users are alloted a Dynamic IP insted of Static...any ways go to start my network conn(just below the cpanel icon)-> show all conn ->properties(of the 1 with yellow exclemeation) ->next reinstall all the protocols like TCP/IP etc and see if it works ...elso right click on it and click disable ...next go to start->cpanel-> internet options->connections->delete all the conn....reboot again go to internet options and under conn create a new conn ..and try to connect...guess u will suceed this time...but if u again get the "?" right click and click on properties -> enable Lan conn .....Hope it solves ur problem....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 06-06-2005, 09:58 PM   #4 (permalink)
anandk's Avatar
thanx for replying, friends.
i had to go to network connections>local area connections>properties>internet
protocol>properties & fill in the IP & subnet addresses & dns server
adresses, manually.
however my broadband speed is still slow, for which i will have to
contact bsnl now.
Microsoft® MVP
anandk is offline
