Old 05-06-2005, 02:17 PM   #1 (permalink)
Default Any icon making s/w ???
Hi all,
Can any1 tell me about any free icon creating s/w?? and from where to dload the same??
TIA
_lordJaz is offline
Old 05-06-2005, 04:58 PM   #2 (permalink)
free ?
im sorry i dunno of any free ones
the better ones (shareware) are stardocks' icon developer
and microangelo which is very old. . i wonder what happened to it
anyways then theres axialis icon workshop to convert png's to ico's
No Mercy, No Limits.
theraven is offline
Old 05-06-2005, 06:25 PM   #3 (permalink)
Biplav's Avatar
hey raven, i got aston and wat i see is when i take my mouse pointer to any icon it changes like its animated. it looks good and the format of the icon was png or something of that sort.
now how do i make those kind of icons tat would animate when clicked ???
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 05-06-2005, 06:28 PM   #4 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
I don't think there is a way to create animated icons for Windows... If there is any, I'd love to get my hands on it !!!
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 05-06-2005, 08:58 PM   #5 (permalink)
club_pranay's Avatar
u dont have to search for the software dude!!
1. open ms paint
2. Press ctrl+E
3. set height and width 80 pixels
4. draw your own icon
5. save as *.ico
you're done!!
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 05-06-2005, 08:59 PM   #6 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
1. open ms paint
2. Press ctrl+E
5. save as *.ico
you're done!!
Nice tip but softwares like MicroAngelo are much better.
navjotjsingh is offline
Old 05-06-2005, 09:04 PM   #7 (permalink)
Biplav's Avatar
I dont know whether there is a way to create or not. but with aston when i move my mouse over it, the icon animates
I suppose this has been created so we should also be able to do so.
Biplav is offline
Old 05-06-2005, 09:37 PM   #8 (permalink)
Fresh Stock Since 2005
1. open ms paint
2. Press ctrl+E
5. save as *.ico
you're done!!
Will this create real iconz...........
I really doubt it..............
http://www.khattam.info
khattam_ is offline
Old 05-06-2005, 09:45 PM   #9 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Yup, it sure creates REAL iconz But no one has yet given any info on animated iconz... I don't think th Windows shell allows it...
Flickr!
Kl@w-24 is offline
Old 06-06-2005, 12:01 AM   #10 (permalink)
macaddict
gauravsuneja's Avatar
best so far is axialis icon workshop crack it buddy
www.drgauravsuneja.blogspot.com
An Apple a day keeps virus away
gauravsuneja is offline
Old 06-06-2005, 01:19 PM   #11 (permalink)
@biplav.. thats what aston does ...
it probably has settings for it
afaik theres no way to create "animated icons"
and yeah completely forgot abt the ms paint trick
it definitely works and can be quite easier
thanx @club_pranay
theraven is offline
Old 06-06-2005, 01:29 PM   #12 (permalink)
1. open ms paint
2. Press ctrl+E
5. save as *.ico
you're done!!
well brother, it works, as far as i know.
the best thing about it is that you dont have to install a seperate software for creating icons!!
Old 06-06-2005, 11:25 PM   #13 (permalink)
Biplav's Avatar
bad.
no way to create animated icons. huh? wonder how these programs do it.
Biplav is offline
Old 06-06-2005, 11:28 PM   #14 (permalink)
Gaurav's Avatar
Microangelo 5.5.9c is the best. SHAREWARE. search for it's full version through google you will get it.
Gaurav is offline
Old 07-06-2005, 12:47 AM   #15 (permalink)
Default GConvert is the king...makes cursors too
GConvert is a full-featured icon toolkit that everyone who likes icons should use: with it you can extract, view, create, edit, manage & convert icons without requiring any additional tool or knowledge.
GConvert extracts icons from files and displays them in a list: you then select the icon you want and it can converted to the format of your choice. GConvert reads any icon files such as executable, DLL, ICL, OCX, VBX, CPL, BPL, NIL, IL, SCR, CUR, ICNS, ZIP, RSRC files and allows you to save extracted icons as icon, bitmap, PNG, Adobe Photoshop PSD, and many other popular formats (JPEG, GIF...); copy them to the Windows clipboard or drag/drop them for direct use into your applications, documents, Web pages...
Get the latest (shareware) version (4.1) at http://www.gdgsoft.com/gconvert/
a5+4l@V1St4...b@BY
tekkrazy is offline
