Old 09-02-2009, 04:56 PM   #1 (permalink)
Sridhar_Rao's Avatar
Thumbs down how to force shutdown
There is something wrong with my dell laptop. Ever since it installed one of the microsoft automatic updates, it refuses to shut down. There are no viruses on my system as I have checked them with updated definitions. Going back via system restore helps temporarily but the updates gets installed automatically again. I don't want to disable this because I don't want to be left out of some critical updates.
Despite shutdowns or restarts, the laptop doesn't respond. Even selecting the shut down option from the task manager (ctrl+alt+del) doesn't help. Currently, I end all the services one by one in the task manager until the sytem itself decides to restart.
What is the alternative to forcing the computer to shut down
Want to study M.Sc in any medical subjects? Read this www.microrao.com/msc.htm
Microx, a diagnostic microbiology laboratory software application www.labmicrox.com
Sridhar_Rao is offline
Old 09-02-2009, 05:16 PM   #2 (permalink)
Default Re: how to force shutdown
You can try
shutdown -s for normal shutdown and
shutdown -f for forced shutdown.
Enter in run dialog box.
ThinkFree is offline
Old 09-02-2009, 07:52 PM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Double click on this tool and your system will shutdown in two seconds.
Shouldn't be used often...
http://www.mediafire.com/download.php?n0zemzdjqwz
Nokia N86 8MP
Lucky_star is offline
Old 09-02-2009, 10:36 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ I think its shutdown -f -t 0 probably.
dheeraj_kumar is offline
Old 09-02-2009, 11:10 PM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
No, it isn't that
"shutdown -f -t 0" takes you through the logging off process before shutting down.
But with this, just double click and the computer powers off instantly, as if the power cable is removed that too within a second. That's why I use it in emergency only. Why don't you try it yourself?
Nokia N86 8MP
Old 10-02-2009, 05:28 PM   #6 (permalink)
my name defines me
cyber's Avatar
well,if we just press ctrl and the shut down option in the task manager at the same time and hold it the computer will shut down in seconds.
i did not get problems while using this but i dont know how safe it is.
cyber is offline
Old 16-02-2009, 07:54 PM   #7 (permalink)
Thanks for the replies.
The shoutdown.exe appears suspicious after I ran a scan with Ashampoo as well as Kaspersky.
Ashampoo reports:
The file shutdown.exe contains Riskware.Risktool.Win32.Shutdown.c!A2
Kaspersky reports:
not-a-virus:RiskTool.Win32.Shutdown.c
It might be a false positive detection, but is it really the worth the risk?
Old 16-02-2009, 07:59 PM   #8 (permalink)
damnbadman666
damngoodman999's Avatar
Just press & hold the power button in the cabinet !!! it is the real force shutdown !!!
over
damngoodman999 is offline
Old 16-02-2009, 08:38 PM   #9 (permalink)
Overlord v2.0
alexanderthegreat's Avatar
If a virus is masquerading as the shutdown.exe, no wonder you can't shut down! If the you try to shut down, the virus is executed instead of the real shutdown.exe. You should obtain another instance of shutdown.exe and replace this one or try to look for removal tools for Win32.shutdown.c. Risktool.win32.shutdown.c IS a known virus, mind you!
Also, try htis page here:http://www.computerhope.com/issues/ch000285.htm
The Only quote worth quoting: "E Loboa!!! What man???
Forum Rules:http://www.thinkdigit.com/forum/announcement.php?f=16&a=1
Disclaimer:No offence meant to ANYONE!
alexanderthegreat is offline
Old 17-02-2009, 07:31 PM   #10 (permalink)
The shutdown.exe -f does not work.
Even the shutdown/restart/logoff in the task manager too doesn't work.
Holding down power button is the brute shutdown which can be bad for computer's health and should not be done often.
This works!!! But, I am not sure the problems this can cause, because it shuts down just the way it shuts when power button is held down.
This is for win 95/98/ME and not for XP.
Old 17-02-2009, 10:03 PM   #11 (permalink)
The program Lucky_Star posted does the following, if anyone needs to know how:
1. Call RtlAdjustPrivilege to give SE_SHUTDOWN_PRIVILEGE to the application
2. Call NtShutdownSystem to shut down the system immediately.
I can post inner workings of NtShutdownSystem if anyone cares.
Force resolutions Plasma_Snake Open Source 2 01-08-2008 09:13 PM
AMD to cut 10% of work force Gigacore Technology News 2 09-04-2008 10:06 AM
How to force 1440 x 900 avikchaks Open Source 2 26-10-2007 01:43 PM
Windows SHUTDOWN Problem, system freezez on shutdown screen catch_maxi Software Q&A 2 16-03-2006 07:38 PM
"improper shutdown" msg on proper shutdown mvishnu QnA (read only) 2 26-02-2006 06:50 PM
