Old 04-06-2005, 09:36 PM   #1 (permalink)
Fresh Stock Since 2005
Default RAM RAM
I had 128 Mb PC133MHz RAM on a VIA V845SX Motherboard with a P4 1.7GHz processor and ran XP Pro SP2. I decided to add more RAM and got another RAM of similar configuration but of different company. I put them together and the problem began. My computer started freezing a lot. BSODs on XP saying PAGE_FAULT_IN_NON_PAGED_AREA repeated. I reinstalled XP but in vain. I downloaded Memtest which either showed errors or just hung.........
I tried Memtest on individual RAMs at their respective slots and they do not show errors. They show errors only when they are together. I tried putting them in different slots but in vain. Is there any way to rectify this?? Maybe some motherboard setting or something..............
http://www.khattam.info
khattam_ is offline
Old 04-06-2005, 09:55 PM   #2 (permalink)
Default hm
same prob ith me . you need to check the ram modules maybe they are not compatible.check em with mem test with dff memory ..
sagsall4u is offline
Old 05-06-2005, 02:06 PM   #3 (permalink)
check the clock and the spd inf
Happy Computing :lol:
krishnathelord is offline
Old 05-06-2005, 11:32 PM   #4 (permalink)
sidewinder's Avatar
ram nam sattya hai !!!! anyway u should clear cmos.then try to force the rams manualy to run at a perticuler speed rather than running them with auto settings in bios
Bombina rocks
sidewinder is offline
Old 06-06-2005, 06:50 PM   #5 (permalink)
Just Do It
Charley's Avatar
Default Re: hm
What is the mode of inserting RAM modules in a PC.....
Charley is offline
Old 07-06-2005, 12:49 AM   #6 (permalink)
Default Re: hm
Remove the already installed RAM module then insert the RAM that is smaller in SIZE or slower in speed in the 1st Slot then the next then so on and so forth !!!
Now u should not face any problems unless u will hav to cange ur jumper settings on ur board !!
Cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 07-06-2005, 02:30 PM   #7 (permalink)
Just Do It
Charley's Avatar
Not with that jumper setting again .... I had a head ache finding that out.....
Charley is offline
Old 08-06-2005, 06:27 PM   #8 (permalink)
Check the book that u should have got with ur MOBO !!!
CHeers !!
