Old 04-06-2005, 07:33 PM   #1 (permalink)
Default Quality of sound
I am using Windows XPSP2 Home Edition. I would like to record my voice with the help of Mic. So, what are the adjustments to be made or altered to get a good result? Your detailed reply,please.
kumarn_2004 is offline
Old 10-06-2005, 05:07 PM   #2 (permalink)
first make sure that ur mic wire should attach to CPU then double click on sound icon of status bar
then volume contro box will open
then click on option->property->select recording->
select microphone then click on ok button.
to record the voice
click on start->programme->Accessories->Entertainment->Sond recorder.
Then here are u free to record sound.
go mate
\"As soon as you trust yourself, you will know how to live.\"
- Goethe
bendre123 is offline
