Old 06-02-2009, 10:14 PM   #1 (permalink)
User Name's Avatar
Default Do torrents reduce HDD performance?
Do D/L from p2p clients(utorrent) reduce HDD performance?
I found my PC HDD performance reduced. folders opens slowly. prog. closes slowly.
is it becoz of many read/write operations of HDD during D/L torrents files.
How to check hdd preformance any software?
There is no virus in my PC.
User Name is offline
Old 06-02-2009, 10:23 PM   #2 (permalink)
It's true Im not confused
confused!!'s Avatar
Default Re: Do torrents reduce HDD performance?
Torrents reducing performance..never heard of it really
After the game is over, the pawn and the king go into the same box
confused!! is offline
Old 07-02-2009, 12:53 AM   #3 (permalink)
siddharthmakwana's Avatar
just defrag ur HDD n it will work good.....
siddharthmakwana is offline
Old 07-02-2009, 09:58 AM   #4 (permalink)
Pragadheesh's Avatar
=Do D/L from p2p clients(utorrent) reduce HDD performance?
downloading from torrents might affect hard disk performance. not sure of it.
check this to avoid torrent damaging the hard disk
Your hard disk performance might be degraded due to bad sectors which make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.
you can use softwares like TuneUp utilites or HD Tune
Pragadheesh is offline
Old 08-02-2009, 03:36 PM   #5 (permalink)
Torrents not reduce hdd performance but it does busy hdd sometimes when downloading
In slow & old system u can feel it
But after all torrents are superb, downloading 90% thru torrent
iane is offline
Old 08-02-2009, 11:34 PM   #6 (permalink)
Smile Re: Do torrents reduce HDD performance?
not really.. torretns never affect ur HDD by any means..
if u dnt have any virus then either ur RAM is too low to support many tasks running simultaneously.. dats why, may be ut HDD runs slow...
upgrade the RAM, or may be ur HDD partition containing the OS might be too full.. try to clean it up..
else simply defragment ur HDD.
ur problem will be solved for sure.
gaurarpit is offline
Old 09-02-2009, 03:52 PM   #7 (permalink)
If you are using P2P and you have shared some folders your PC would run slowly. Its actually because the P2P software generates the hash links for all the files shared, which is then uploaded and the other users of the world can search from and download from you. And this process is done quite frequently. The hash links are updated many times.
For example, I used Ares as a P2P software on normal when the hashing functions run on the background you would see a CPU usage of around 30K - 55K. Whereas when the Ares was just downloading and not generating the hash links the CPU usage would be around 3K-5K.
So if you want to use P2P softwares don't share any folders. But that would be a bit unfair on the P2P world as it would only take and no give!!!
Well this is just a P2P perspective, never heard of torrents doing harm!! This is the first!!!
hell_storm2006 is offline
Old 09-02-2009, 10:28 PM   #8 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Nah, the read and write requests to the hard disks are highly frequent during P2P transmission and reception. Thats the reason for the slowdowns. I've got a tip for you - Put all your downloads or shared files in a seperate partition, dont put anything else in that partition, and use a automatic defragging tool like PerfectDisk to take care of it. Trust me, works perfectly
dheeraj_kumar is offline
Cant Reduce LDT..... anilthomas26 Hardware Q&A 3 23-05-2007 04:04 PM
How to reduce the size of an MP3? aryayush Mobiles and Tablets 9 30-05-2006 03:12 PM
how to reduce vocals? nix QnA (read only) 3 09-05-2006 01:54 PM
Reduce size ! ! ! ax3 QnA (read only) 3 13-12-2005 09:16 PM
Way to reduce Piracy Anonymous QnA (read only) 49 21-05-2005 03:24 PM
