Old 04-06-2005, 01:29 PM   #1 (permalink)
Default EVERYTHING IS PLAYING TOO FAST
I gotta problem,,,,evrything i play in windows media player (muisc,movies) plays very fast......like fastforwarding,,..
when i change the device properties and select a modem or gaming (emulated) audio device instead of my standard sound card....it plays at normal speed but without sound!
I tried other software and they have the same problem too....
except WINAMP but it cant play VCD
Please help me......or tell me where i can find a winamp plugin which can play VCD
chillnow is offline
Old 04-06-2005, 06:39 PM   #2 (permalink)
Click on the view menu in windows media player and unde enhancements choose "Play Speed Settings" you have 3 options there slow normal and fast. Check those settings and and set it as you wish
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
Old 04-06-2005, 08:19 PM   #3 (permalink)
well.........i dont have that option(play speed settings) anywhere....
i have windows media player 9 series
chillnow is offline
Old 04-06-2005, 10:43 PM   #4 (permalink)
vishal_bhatia87
Posts: n/a
To download the winamp(2.xx) video plugin go here:
http://www.winamp.com/plugins/details.php?id=131443
Try updating Wmp, Soundcard drivers and DirectX.
Old 05-06-2005, 10:52 AM   #5 (permalink)
I use WMP 9 on windows xp. Try updating your WMP. Just look for one in DIGIT cd's
shyam911 is offline
Old 05-06-2005, 01:29 PM   #6 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
In WMP, go to View>Enhancements>Show Enhancements. There, click on th small arrows till u reach "Speed Settings".
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 06-06-2005, 09:08 AM   #7 (permalink)
No....i still dont have the 'play speed setting' option.
The following plugin "http://www.winamp.com/plugins/details.php?id=131443" only works with Winamp2x nd not winamp 5
chillnow is offline
Old 06-06-2005, 09:31 AM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
chillnow dear try the answer by kl@w-24
but this guys i dont think wmp settings isnt the caprit.... from my experince that i have with this kind of problem... this happen dew to curropt installetion... or dew to old DirectX version.....
mate what version of directX do u have??
& yes try to update it to wmp10.......
Choto Cheeta is offline
Old 06-06-2005, 12:28 PM   #9 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
If ur problem isn't solved, go to [Start]>[Run]>dxdiag to run Direct-X diagnostics which will tell u if there r any corrupt or missing DirectSound files.
Flickr!
Kl@w-24 is offline
Old 06-06-2005, 07:31 PM   #10 (permalink)
chinmay's Avatar
i m sure its the play speed settings problem...dude call a techie in ur home...he'll do it for u in 2 mins...
I Blog at - http://www.chinmayspeaks.com
chinmay is offline
Old 06-06-2005, 07:46 PM   #11 (permalink)
expertno.1's Avatar
might be some codec problems
get some good codec packs
i faced it one time but only for WMP
and after installing codecs problem solved
check it out also
like get nimo codec pack
expertno.1 is offline
Old 12-06-2005, 04:20 PM   #12 (permalink)
Damn it.....i uninstalled the WM9 to WM6(i got 98) and then downloaded and reinstalled WM9 back again.........i installed Nimo Codec Lite also......still the problem prevails.....
I reinstalled my sound drivers too and there are no problems in directx sound.
i cannot yet find the 'play speed settings' option.....coz its not there.
I got Win98...My winamp 5 plays normal and fine but WM9 just wont stop fastforwarding
HELP!!!!!!
chillnow is offline
Old 13-06-2005, 08:10 AM   #13 (permalink)
vignesh's Avatar
I had that problem once with my nvidia card while using win 98.There is autofix patch for nvidia on my motherboard cd then it worked ok.
vignesh is offline
Old 13-06-2005, 07:47 PM   #14 (permalink)
Rebooting
ok then... u have win98.... so u jast have to reinstall the windows.... reinstalling wont going to cost u loss of data in win98.... so just go 4 a reinstall without formating the os drive....
