04-06-2005, 01:16 PM
Which is the best Torrent client?
I'm new to torrents.Which is the best Torrent client?
I use BitTorrent 4.0 now.
Thanks!
04-06-2005, 01:35 PM
Bittorrent 4 is one of the most basic torrent client.....it has no options i guess. I use BitLord in which can do a lotta things like checking tracker,seeds,peer,leecher,priority,torrentsearch, scheduling.....its one of the best!
04-06-2005, 01:46 PM
I use Azureus 2.3.0
and take my word for it....
it simply rocks dude...
has a lots of features...and looks cool too...
and ya it has many config options...
so tht u can suit ur need....and ya it has a lot of cool plugins too
Ai yo!!
04-06-2005, 02:04 PM
Get Azureus 2.3.0.2. You will need Java Runtime Environment to run the same.
04-06-2005, 02:05 PM
Another Brick in the Wall
Hmm...
I like Bit tornado 0.3.10 , it's simple and easy to work with. The interface is also not cluttered.
When i need to open up more than one torrent file, then i go for BitComet
04-06-2005, 02:41 PM
i prefer Bitcomet
04-06-2005, 03:31 PM
another vote for bitcomet....it gives me very consistent speeds....
04-06-2005, 03:48 PM
Thanks guys!
I'm downloading a file using bittorrent.It's 43% finished.
If I install Azureus or BitComet,can I transfer the file I was downloading to these...?
...or should have to wait till the file completes downloading & then install Azureus or BitComet.
04-06-2005, 04:12 PM
Coming back to life ..
Azureus is the best IMHO .. Even Shareaza sometimes performs nice for torrents ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
04-06-2005, 05:23 PM
I am Optimus Prime
I also prefer BitComet.
04-06-2005, 05:31 PM
QA Juggler
well my vote goes for Bitcomet .....though will try Azureus soon.....to se if its better than Bitcomet
8-) सारोमान :!: :!: :!:
04-06-2005, 05:51 PM
Originally Posted by bharat_r
Thanks guys!
No, u can downlaod with other clients also. Just point the client to the partial download folder and it will automatically resume the download..
04-06-2005, 08:23 PM
I can't understand what u say drgrudge.
What I wanted is:
I'm downloading a 1.2 GB file in BitTorrent 4.0. It 50% completed.
I don't want to use BitTorrent 4.0 now.I installed Azureus 2.3.0.2.
How do I open the torrent file so that download resumes from 50% in Azureus.
04-06-2005, 11:06 PM
Ok do as i say:
1. Stop the torrent from bittorrent. (pause it and not stop it)
2. Install and run azereus.
3. File --> open torrent, now select the partial downloaded file (50%).
4. Azereus will check for existing data, and will continue from 50% if all the 50% packets had been saved in your HDD. Even if starts from 45-47% dont worry.
5. Now the torrent will work properly and u will able to finish the torrent.
6. Remember to seed after you finish the download.
Did u try BitTornado 0.3.10 ? It's very simple and a good client
04-06-2005, 11:10 PM
I am Optimus Prime
Originally Posted by drgrudge
Ok do as i say:
Excellent info. Will be very useful for me since i download most from torrent.
04-06-2005, 11:19 PM
bitcomet 4 me
open ur torrent file with bitcomet , select the folder where u were d/ling the file earlier , n then choose resume . click OK
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
05-06-2005, 02:31 AM
Thanks drgrudge understood now.
The votes so far:
_________________
Azureus :3
BitLord :1
BitTornado :2
BitComet :5
_________________
05-06-2005, 07:23 AM
bharat_r, dont take anyone's word as it is. U can try out various client and see which one suits you better.
The Four top clients that I've used and liked are BitComet, torrentopia, BitTornado and ABC.
I guess the best way to find out the best client for you would be to try out each for a week or so and see which one has features/Interface that you like and runs well on your system. Why I say that you should try them out yourself is because for some reason some clients perform better on some systems than others, an example is Azureus, it runs perfectly well on my friend's PC but when I run it on mine it slows down the system. However I've known BitComet to perform better on most sytems and not using too many resources hence system doesn't slack.
Also one client may have feature(s) that may be more handy to you than other clients so its best if you try them all out and decide. For example I personally Like ABC's web interface, meaning you can add/control your torrents over the web which is handy if you're away from the PC...and its easy to setup and use(BitComet also has it but it takes some basic coding to get it working)...
So Take these things in account:
1. System resource
2. Interface u r comfortable with
3. Better speeds.
I find Bit tornado 0.3.10 better
06-06-2005, 08:32 PM
#19 (permalink)
I've tried BitTorrent,BitTornado & Azureus.
I found Azureus to be the best.
It has the coolest interfaceand also understandable by me.
will try out BitComet & ABC next.
07-06-2005, 10:54 AM
#20 (permalink)
l33t n00b!
Do try out BitLord too. It's very good. In fact I find it to be the best.
07-06-2005, 11:29 AM
#21 (permalink)
i tried azureus....the java thing it starts takes my computer usage to 100% !!!....why is that??
07-06-2005, 01:55 PM
#22 (permalink)
^^ Azu is based on java so unless u got a good and a fast system, then dont go for it.
Bit tornado and bitcomet (based on C++) take less system resources...
08-06-2005, 11:55 AM
#23 (permalink)
dude i have a P4 with HT, 3 GHZ,512 DDR RAM, 80GB, 5200Fx HP pavilion.....but azureus still makes it slow...
08-06-2005, 12:27 PM
#24 (permalink)
hmm no one uses abc 3.0?? its based on bit tornado..
its pretty good, simple and clean interface... its like bit tornado with a Better GUI.. lol
ohh i use bit tornado 0.3.10 too to download stuff...
i had used azureus b4... somehow i never was able to download as fast as i can on abc/Bt ...
bit comet is good too.. do use it sometimes..
its my gift....
its my curse....
who am i??
i`m spiderman....2!
15-08-2005, 06:57 PM
#25 (permalink)
I guess BitLord is the same as BitComet...its just like another skin for BitComet. So 8 votes for BitComet...it WINS!!!
15-08-2005, 07:06 PM
#26 (permalink)
I am also new to torrents. Pl tell me from where do I download Azureus
15-08-2005, 08:07 PM
#27 (permalink)
go for bit tornado -- i find it the BEST
The Knight Rider
WELL YOU GONNA ALWAYS WIN
The Best Way To Contact Me Is, E-Mail Me
Get A GMail Account @ www.mbdw.s5.com
15-08-2005, 08:17 PM
#28 (permalink)
Yup. I use Bit comet.
Death keeps smiling at us all the time, all we can do is Smile back.
15-08-2005, 08:19 PM
#29 (permalink)
Commander in Chief
Jus search buddie...
Edit this if illegal...
azureus.sourceforge.net
Harsh J
www.harshj.com
15-08-2005, 09:07 PM
#30 (permalink)
I use abc and it i think it is quite good. Now going to try Azureus.
Search this Thread |
