Old 04-06-2005, 12:46 AM   #1 (permalink)
Can you hear it..??
windchimes's Avatar
Default configuration for a computer
hi,
can you please help me to get the best configuration for a computer which can be used for highend graphics work like 3d animation,editing etc
which processor should i opr for AMD/INTEL..specify the model..n which is the best graphics card tht can serve the purpose...i wud like to see an entire list of the configuration.
windchimes is offline
Old 04-06-2005, 01:42 AM   #2 (permalink)
Aniruddh's Avatar
well 1st of all wats ur budget dats da most important thing.u r lookin 4 a pc 4 3d animation,editing games etc den u dun hav 2 think twice juz go for a AMD platform rite now i m using AMD 3000+(939 soc) wid MSI RS480M2 mobo it has 128mb onboard graphics.hav played all da latest games like farcry etc had no problem wat so ever.dis config is givin me excellent performance.well u can go for a xfx,leadtek 6600gt card its gud and yaa if u can den gainward is da best u can get.so plz do lemme kno wats ur budget so dat i can give u my suggestion.
Aniruddh is offline
Old 04-06-2005, 01:14 PM   #3 (permalink)
The Hardware Labs
mohit's Avatar
i think intel processors are better suited for editing purposes and benefit a lot with the hyper threading technology ... amd is the best for gaming but i dont think that is ur purpose. if u will wait for some time intels new dual core processor is on the horizon and u can buy the 2.80 pentium d which will be costing around 13-14,000/- .
i think nvidia quadro series are the best cards for 3d grafix work but they are very very expensive.
also make sure your system has enough RAM (atleast 1 gb).
mohit is offline
Old 06-06-2005, 06:51 PM   #4 (permalink)
Just Do It
Charley's Avatar
What kinda budget u looking for. There are many ranging from avg cost to high cost comps....
Charley is offline
Old 07-06-2005, 12:32 AM   #5 (permalink)
if u have a budget of approx 35k u cam go 4 a good comp !!!
Go in for AMD !!!
hey get ur self a K8N-E DELUXE u can connect upto 6 SATA drives in raid !!! for ur requirements u will require SPace i would recommend 2*80gb or 4*40gb in RAID 0 or 1 its will be muc faster then a single huge drive !!!!
Cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 07-06-2005, 02:41 AM   #6 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Go in for AMD !!!
Cheers !!!
What are you posting......
Let him post the details...there is no use discussing if u have a budget of
Whats use in ......... If he has this budget!!!
rollcage is offline
Old 07-06-2005, 09:18 AM   #7 (permalink)
what are you all saying
msi rs 480 and gaming , can you even call ita low end card,isn't it closer to entry level and crap
also,fr 35k you only get junk
for your purpose 80-90k or higher may do
akshayt is offline
Old 07-06-2005, 02:32 PM   #8 (permalink)
ya i kinda agree with akshayt.. first your budget.. and i think for 3d animation. the quadro series is better...
i used to use a machine with a quadro fx when i was learning 3d max...
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 08-06-2005, 12:52 AM   #9 (permalink)
well 1st of all wats ur budget dats da most important thing.u r lookin 4 a pc 4 3d animation,editing games etc den u dun hav 2 think twice juz go for a AMD platform rite now i m using AMD 3000+(939 soc) wid MSI RS480M2 mobo it has 128mb onboard graphics.hav played all da latest games like farcry etc had no problem wat so ever.dis config is givin me excellent performance.well u can go for a xfx 6600gt card its gud.so plz do lemme kno wats ur budget so dat i can give u my suggestion.
Dude can you tell me about the Sound quality of the onboard sound of this card i.e MSI RS480M2. A comparison of sound and graphics with Intel's 915 GAV motherboard would be great - since i am planning to buy one of these.
Thanks,
imjimmy is offline
Old 08-06-2005, 12:11 PM   #10 (permalink)
Aniruddh's Avatar
@imjimmy
well onboard sound is quite gud but if u compare it wid 915 den i guess 915 has a betta onboard sound quality.but its onboard graphics r really very gud.in most of da 915 chipset der no onboard graphic few hav but RS480m2 graphics r betta if i m rite.well people who hav 915 chipsets mite tell u da exact diff between da 2.
Aniruddh is offline
Old 08-06-2005, 04:19 PM   #11 (permalink)
amd 64 bit's are better performers than intel in video editing also in real life....Couple it with good RAM and SCSI HDD's if u r a serious VIDEO editor, then u have to go for some decent Graphic card like Quadro, if ur job involves working heavily with 3D applications.
Rajeev V Nair
premrajeev is offline
Old 09-06-2005, 02:51 AM   #12 (permalink)
rollcage's Avatar
Originally Posted by Aniruddh
@akshayt
if u r gonna giv 80-90k den i'll mak sure dat he takes da config u suggested .if u can den plz gemme 2 . man i really dun understand ur fundaz at all.crazy.instead of any help ur post create hell of a confusion. .nywayz.
Mind your language...
.....if you dont know anything
Better Keep Your Suggestions With You Only
rollcage is offline
Old 09-06-2005, 03:13 AM   #13 (permalink)
rollcage's Avatar
@akshayt
You are damm right dude...
This type of work require high end rig
rollcage is offline
Old 09-06-2005, 05:03 PM   #14 (permalink)
Aniruddh's Avatar
@rollcage
1st of all i hav edited my post as u didnt like it.but wat wrong did i say?not everyone can spend 80-90k.and dat fellow wanted 2 kno dat wat best he can get in his budget and v shud suggest thins which fits into his pocket as simple as dat.
Aniruddh is offline
Old 09-06-2005, 10:25 PM   #15 (permalink)
Can you hear it..??
windchimes's Avatar
hi,
thanks for all the replys...i've a budjet of 45K...n it seems it is not enuf. can u suggest a config within this amt.
Windchimes
Old 09-06-2005, 10:56 PM   #16 (permalink)
Aniruddh's Avatar
@windchimes
1.ASUS A8N-E or MSI K8N-Neo 4 platinum Mobo-9k.
2.AMD 3000+(939)-7k
3.Samsung 17'' Magic Brite2 Monitor-8k
4.512 DDR (400mhz)RAM-Corsoir,Kingston-3.5k
5.80GB Sata Seagate-3k
6.Sony-CD-RW,DVD-ROM-2.8k
7.UPS(600VA)-2k
8.400w SMPS-3k.
9.Cabinet of ur choice-1.2k
10.Logitech keyboard and optical mouse-1k.
11.Creative 2.1 Speakers-1.4k
well now u hav 3.2k left and dis mobo dont hav any onboard graphic so u hav to go for a card,5300 PCI-E card which will cost u some where around 3.2k which is not bad and wid dis budget i guess u hav 2 compromise rite now u can use dis and later u can save and u can take 6600gt,eva speaker i hav suggested u will b a big issue.i m sure loads of dem r gonna object for both Speakers and GPU so lets c wat others hav to say but i think this is the best u can get in 45k or else u can go for AMD(754soc) wid NForce3 chipset.guyz any other card posible???if yes then plz tell us eva any other config...this is the best i can suggest.
Aniruddh is offline
Old 10-06-2005, 06:46 PM   #17 (permalink)
Aniruddh's Avatar
well tell him if this config is good or not and eva tell if he can get somethin betta then dis for 45k.wind i guess u shud go for dis config da one i suggested u dis is da best u can get for 45k.do tell us wat u hav decided at the same time do post the price u r gettin for ur rig.
Aniruddh is offline
Old 10-06-2005, 10:24 PM   #18 (permalink)
Can you hear it..??
windchimes's Avatar
hi anirudh,
Thanks......i'll let u know my decision ...but probably i'll wait for a few more months... since my p3 machine is workin fine..Anyway thank u all
for ur kind help
windchimes
