Your standalone DVD player has better error correction than the drive in your PC. It's just that. Nothing more, nothing less.
http://www.thinkdigit.com/forum/view...&highlight=dvd
Your options -
1. Try disc cleaning kits. (Not lens cleaning, but disc cleaning
2. Buy a new DVD drive.
3. Try Alcohol 120% to create an ISO image (will skip bad sectors/errors). Mount image using Daemon Tools (use the same to make a virtual drive). Now, rip using whatever methods you generally prefer.
Note: I've never tried Alcohol 120% to make a scratched DVD image before - no guarantees here.
another thing.......jst tell me how come the conventional dvd players play dvds fluidly inspite of scratches......dont tell me those r better than our sweet little combo drives Razz
YES, they are. And that's what they're designed for. Play any damned disc you throw at it. It all boils down to error correction. A standalone DVD player will just skip when it sees a (minor) scratch. Unlike PC DVD drives that read every bit on the disc and make a big fuss when something is missing. This is essential for data as you can't afford to skip stuff (and create corrupt data files)
and is thr anyway to alter the dvd or cd read speeds of ur drive...... if so how??
YES. I have modified drive firmware before updating to change DVD read speeds (8X, 12X, 16X) and also modify write strategies for individual disc types. The drive in question here is a Sony/Liteon and firmware customization was done using Omnipatcher.
http://codeguys.rpc1.org/patchers.html
http://codeguys.rpc1.org/firmwares.html
Keith
