hey Thor ... converting a CD-ROM drive into a Mp3/VCD player is a tough job... I know how 2 convert ur Drive into a simple audio CD player .. buy a SMPS Power supply [12V-5V-GND-(-5V)-(-12V)] connect the 4 pin power socket into the Drives back..then plug a earphone into ur drive's analogue audio out socket in the front face of the drive... u can control the tracks, vol. contrl etc from the press-switches on ur Drive's front panel. But to convert it into a VCD player u can refer to the JAN 2000 issue of ELECTRONICS FOR YOU magazine (
www.electronicsforu.com) whr they hv used a MPEG decoder card (costs around Rs 1000) to convert an audio CD player 2 a VCD player. U hv 2 kno soldering coz u hv to open up the drive in order 2 locate a IC Chip (listed in the magazine) and locate a certain EFMin Pin of that which will be ur video out pin which will be connected to the signal in of the decoder card... refer to the magazine and u'll kno about the knohows !!! [/url]
