Old 03-06-2005, 04:47 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default what is the minimum requred ram for a home pc
gary4gar is offline
Old 03-06-2005, 07:16 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
128mb shud b fine. i use winxp sp2 on it with no probs.
but if posble better 2 go for 256mb ram.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 03-06-2005, 07:47 PM   #3 (permalink)
if u can afford it id say 512 ...
its gonna become the new standard very soon !!
so id rather u get atleast that much if u can
else 256 should be ine for now
the thing is it completely depends on ur usage
256 is good for anything from email to surfing
if u wanna play games then 512 mb ram and a good graphics card is a must
No Mercy, No Limits.
theraven is offline
Old 03-06-2005, 08:18 PM   #4 (permalink)
256 min. 512 preferable
paraman is offline
Old 04-06-2005, 12:38 AM   #5 (permalink)
256 req 4 smooth ( almost ) running of xp . 512 or even 1gb recommended
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 04-06-2005, 12:56 AM   #6 (permalink)
win xp hits the sweet spot at 512MB. Gains beyond that are not worth the money spent.
**** happens
pradeep_chauhan is offline
Old 04-06-2005, 02:16 AM   #7 (permalink)
Depends on what you mean by "minimum required". You can run Win98 with 32MB or even 16MB
Anyway, 128MB is usable if your budget is really tight
256MB will show a big performance jump from 128MB
512MB still shows improvement but but not as much as 128-256
Going above 512MB gives you bragging rights but shows little or no gain except for a few special applications.
For gaming, the order of priority is graphics card, RAM, processor, assuming that no part of the system is too ancient.
pimpom is offline
Old 04-06-2005, 03:00 AM   #8 (permalink)
hahahahaha 1gb is not needed for a home pc, perhaps for 3d apps like maya(rendering should be fast with such memory).
Damn right ... I used 128mb sd-ram for two and a half years, now Iam using 512mb ddr @ 400mhz.
Hibernating ....
banned2wise is offline
Old 04-06-2005, 10:51 PM   #9 (permalink)
Dipen01's Avatar
hey there..
Buddy am using 64 SD RAM (PIII)....Win XP SP2...I will die if i use the sam config for few more months... i am soon planning to buy 256 MB SD RAM....
512 should be best choice...
cheers..
Dipen
I love walking in Rain ,because no-one knows i am Crying :|
Dipen01 is offline
Old 04-06-2005, 11:28 PM   #10 (permalink)
Originally Posted by banned2wise
up2 1gb is fine . after that an overkill 4 atleast now . prices on an all time low . shouldnt b a problem 4 ppl who wanna play games or do some animation or video - editing , or ne other **** besides just surfing or typin in letters
btw , the key word in my post was ' recommended ' 4 the 1gb option . requirement was satisfied with 256mb
mamba is offline
Old 04-06-2005, 11:39 PM   #11 (permalink)
deathvirus_me's Avatar
256 MB if the usage is limited to music/movies only ... 512MB for better performance ....
deathvirus_me is offline
Old 04-06-2005, 11:55 PM   #12 (permalink)
The Hardware Labs
mohit's Avatar
256 mb is good enough but 512 mb is great. also ddr ram prices have fallen down and are still falling... its better to go for 512 mb. and dont forget longhorn will require min 512 mb for a smooth operation.
mohit is offline
Old 05-06-2005, 06:07 AM   #13 (permalink)
Fresh Stock Since 2005
Minimum RAM recommended: As much as you can afford
Maximum RAM recommended: As much as your PC supports
Hope you got it.........
More RAM = Faster Computer
http://www.khattam.info
khattam_ is offline
