Old 02-06-2005, 10:01 PM   #1 (permalink)
Default retrieving text from flash files
Hey frens!
I recieved a flash based cd from my tution centre ... which consists of text too as a part of the interactive chapters.
I wanted to know if there was any software using which i could copy the text from the files and get them printed. If not ... i'll have to WRITE DOWN each n every word!
Do tell me .... i need it urgently
futuristically_ancient is offline
Old 04-06-2005, 11:16 PM   #2 (permalink)
CMON GUYS!
DOESN'T NE1 OF U KNOW HOW TO DO DIS?
Old 05-06-2005, 06:33 PM   #3 (permalink)
expertno.1's Avatar
well thats very .....
ok try this
printscreen any flash image of your monitor when it has fully loaded
then save the image
use any good OCR
and then save the texts
if not then post here .... working on your problem for more......
expertno.1 is offline
Old 05-06-2005, 06:39 PM   #4 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
U can try th demo of Action Script Viewer. See if it helps...
http://208.234.6.28/asvdemo.zip
OR u cud try SWF decompiler :
http://www.eltima.com/products/flashdecompiler/
http://www.eltima.com/download/flash_decompiler.exe
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 06-06-2005, 06:45 AM   #5 (permalink)
144
144's Avatar
Just explore your CD, see if there are any text files/xml/htm files. Open them and check them out. Also check for *.as files.
See if you find you text if there are any.
Sometimes the scripting is done to load text from other files.
This is just a wild guess...
Else , if it is only the *.swf file, you will have to get a swf decompiler --
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 06-06-2005, 11:44 PM   #6 (permalink)
THANKS A TON DUDE!!!! UR SOLUTION HELPED ME OUT!
Old 06-06-2005, 11:46 PM   #7 (permalink)
ok try this
then save the image
use any good OCR
that MAY b a good advice .... but i guess .... sum other time .... k?
