Re: Which Stone should I buy?
^^if you have plans of (also) listening to radio on this stone then i strongly recommend you TO NOT buy this. The radio is very very pathetic, you wont be able to tune any of the stations. My bro has one and it is really bad on the radio front. It does not matter you are in house or on main radio, radio reception is just plain noise.
Moreover about the radio, It is a known fact and you can read reviews on the net saying so.
