Results 1 to 3 of 3
02-06-2005, 09:47 PM #1
THE RUSTY SCREW PROBLEM!!!!!!!!!!!!!!!!!!!
ive got a rather peculiar( may not be ) problem.
some of the screws that fasten the drives to the cabinet have rusted and all of the screws have lost the shape of the head. hence am unable to unfasten 'em using a screw driver.
so guys got any bright ideas to unscrew the screws.
[[MODS]] : if u think this belongs to some other section please move it .WORK EXPANDS TO FILL THE TIME NEEDED FOR ITS COMPLETION
-------- PARKINSON\'S LAW
03-06-2005, 12:59 AM #2Wise Old Owl
- Join Date
- Aug 2004
- Location
- New Delhi
- Posts
- 1,150
put some rust remover solution to loosen up the threads and use a small hacksaw to make a new head cutting then use a screw driver to unscrew
**** happens
03-06-2005, 01:21 AM #3Wise Old Owl
- Join Date
- Jul 2004
- Posts
- 1,351
As a rust remover you can use light machine oil such as sewing machine oil. Don't apply too much.
Pradeep's suggestion to cut a new slot is a good one. As an alternative, a pair of pincers (used for removing nails) can be used. Grip the screw head very tightly with the edges of the pincers and try to turn it.
Oh BTW, I mean iron nails, not your nails......
Modem doesnt work...SCREW THESE BSNL GUYS!!
By cyborg47 in forum Software Q&AReplies: 4Last Post: 23-03-2009, 01:10 PM -
How to make rusty websites compatible with FF or Opera
By Faun in forum Open SourceReplies: 2Last Post: 07-10-2008, 08:30 AM -
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy???
By sourav_digit in forum QnA (read only)Replies: 3Last Post: 27-12-2006, 02:33 PM -
NFS:Most Wanted Screw Me! Help
By speedyguy in forum GamerzReplies: 6Last Post: 11-01-2006, 03:44 PM -
PC Config - Rusty brains need some help.
By Keith Sebastian in forum QnA (read only)Replies: 11Last Post: 02-04-2005, 11:25 PM
LinkBack URL
About LinkBacks
