Old 21-01-2009, 03:56 PM   #1 (permalink)
Default run apache in sony vaio cr 353
i got sony viao cr 353 some days ago ...as i do litle bit of php ..i was trying to run easy php 1-8(or wamp) but it says
Apache cannot be runned:another server use the Web port
i havenot installed any other program ....like iis and so on...
i found lots of program has been bundled with sony vaio itself..so dont know what is causing the program...(i even removed sql server 2005)
i am using nod 32 as av
even wamp wont run...
please help
thanks
be who u r :
Saharika is offline
Old 21-01-2009, 05:10 PM   #2 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default Re: run apache in sony vaio cr 353
The port that Apache Tomcat is listening on is port 8080 by default.
Modify the Server.xml file Tomcat4\conf directory or Tomcat5\conf and change port to something else like 18099 or 19088 or anything u think...
NB: Reading ur post heading i thought its laptop related but its not
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 21-01-2009, 06:49 PM   #3 (permalink)
i think its not right
i think it uses port 80 not 8080...i have tried using 8080 in http conf file of apache...it didnt help...
its easy php and as far as i know there is no tomcat folder...
any way thanks
be who u r :
Saharika is offline
Old 21-01-2009, 08:11 PM   #4 (permalink)
dude try the ports i have mentioned! 8080 is used by many apps by default like Java etc so try with the ports i mentioned and let us know what happened! And the change i told was in server.xml. there should be something like Connector port
anyways..
Old 22-01-2009, 04:16 AM   #5 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Do a port scan and see which utility is using the default port 80. Stop that service and then try starting Apache.
गीक होना माँगता
victor_rambo is offline
Old 22-01-2009, 11:33 AM   #6 (permalink)
anyways..
well fox,that is not the solution i am looking for...i am trying to know what is causing the problem and make it work....
i am not asking for an alternative way...
more over,i have already said i have tried using other ports from http conf file of the apache...but didnt helped...
plus...if i change the port there are other complication related to it..i have experienced in past...
most of the php script use path to thier script...
http://localhost/scriptname
ie http://localhost/wordpress/wp-admin/
i am trying to migrate many script from desktop to laptop...if i change the port i have to manually change these kind of address of each script...which is easier said than done...
and when i move some script from my laptop to comp...i have to change it again...
so can be easily said(to change the port) than done...and for ur info there are no tomcat folder in either easyphp or wamp installation of apache...
(it is there if we install it separately,apache)
i am not using any java...iis...oracle..even removed sql server....
so what might have caused problem...
i am gong for xampp now...lets see..
be who u r :
Saharika is offline
Sony Vaio Doesn't Hibernate Raaza QnA (read only) 6 18-07-2007 02:18 PM
sony vaio LA38G iMav Technology News 17 25-06-2007 06:42 PM
sony vaio series salils Hardware Q&A 10 08-12-2006 09:03 PM
