Old 02-06-2005, 07:42 PM   #1 (permalink)
ramprasad's Avatar
Default Ctrl + Alt + Del
Hi
I use Win XP with SP2. Recently I installed the OS. If I press Ctrl + Alt + Del, I am not getting the 'Windows Security' window, instead my Task Manager opens... Can u plz help me to solve this problem...
Regards,
Ramprasad
ramprasad is offline
Old 02-06-2005, 09:04 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Its normal. ALWAYS TASK MANAGER WILL OPEN.
Which Windows Security Window are u talking about?
navjotjsingh is offline
Old 02-06-2005, 09:39 PM   #3 (permalink)
himtuna's Avatar
it is not normal earliar when i use to press these keys a window with 1)shut down 2)restart.......6)task manager would appear. But now i am getting directly task manager's window. I didn't install any of the updates but i think i am attacked by malwares & viruses . i even deleted some of the window's folder.
http://www.himtuna.com/
http://www.himanshuthakur.com/
Do good to be good !
himtuna is offline
Old 02-06-2005, 11:06 PM   #4 (permalink)
Default Re: Ctrl + Alt + Del
Originally Posted by ramprasad
Hi
Regards,
Ramprasad
Are u using win xp HOME EDITION or PROFESSIONAL EDITION?
Pressing ctrl+alt+del in either will bring up diferent windows with different options.
If ur using windows professional, try re-installing it. Then wen u press the ctrl+alt+del, a Windows Security pane will pop-up.
I too had dis prob ... but re-installing windows, i got it rectified.
If ur in Win XP Home edition, the task manager will show up.
If ur using any tweaks, try disabling them.
futuristically_ancient is offline
Old 02-06-2005, 11:37 PM   #5 (permalink)
QA Juggler
saROMan's Avatar
well bud am using XP from last 1year..i have tryed all the vaients Pure XP proff/Home...Xp_SP1 Proff/Home...XP+SP2 Proff/Home so when i press Ctrl+Alt+del i always get the taskmanager ..i guess what u r talkin of is feature of 2000 ..and if i am not wrong....Plain Vanilla Xp ....if u have mulitple accs..then u may get the Security screen as u say..but donn wory its OK ..to get Task MGr at Ctrl+Alt+del...
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 03-06-2005, 01:56 AM   #6 (permalink)
It depends on the way the user logs on and off.
Open USER ACCOUNTS in control panel. click " Change the way user logs on and off" and disable "Use welcome screen " and "Fast user switching" and restart computer. Now to log on to windows you have to press ctrl+alt+del and typing your user name and password. after logging when you press ctrl+alt+del you will get the security window.
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 03-06-2005, 05:40 AM   #7 (permalink)
mako is absoultely right. It depends on the way users logon and logoff.
make the changes and you are done. you get this:
RajŪ Anyone else is not me...!!!
rajas is offline
