Old 02-06-2005, 05:24 PM   #1 (permalink)
montsa007's Avatar
Default invalid system disk please replace the disk and press any ke
i hav windows 98
p1
i boot it after veryfying dmi pool data i get the message
invalid system disk please replace the disk and press any key
plz help
montsa007 is offline
Old 02-06-2005, 05:56 PM   #2 (permalink)
Try to access the disk via a bootable windows CD and do a thorough scanning....May be a case of bad sectors...
sumitava_b is offline
Old 02-06-2005, 09:01 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Check if you have a bootable cd or floppy and if you have set hdd as the first boot device.
Take out all cd's and floppys and then switch on. Run Scandisk and try to scan your hdd. Maybe hdd is damaged.
navjotjsingh is offline
Old 03-06-2005, 12:01 AM   #4 (permalink)
QA Juggler
saROMan's Avatar
well Bud ur Master boot record seems to b messed up ....as told already try to boot from ur floppy/CD and see if Windows starts or not.....else i think u will have to format/reinstall 98 again...
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 03-06-2005, 07:27 AM   #5 (permalink)
q3_abhi's Avatar
Well,If ur HDD is the first boot device, Check ur HDD connection. Many a times it happens that ur connections r loose.OR Use a bootable CD/Floppy 2 boot.
q3_abhi is offline
Old 03-06-2005, 10:42 AM   #6 (permalink)
montsa007's Avatar
plz can u give me detailed how to do coz i am a novice and i dont have cd drive
Old 03-06-2005, 12:45 PM   #7 (permalink)
you dont have a cd drive!!! :roll: :roll: :roll: Then how r u surviving??
Okay, fine. Hope u have a floppy drive at least. Ask ur friends for a bootable floppy. Otherwise go to any of ur friend who has a system that runs on any OS except XP. Tell him to create one bootable floppy for u.
Now come back to ur system. From the bios make floppy drive as the 1st boot disk. Then insert that bootable drive into drive and start the sys. It will boot from the floppy in dos and go to "a:/". Now u can use dos commands to access ur hd. First try to scan ur hd. If problem persists then do a format and partitioning by fdisk command.
Old 03-06-2005, 03:31 PM   #8 (permalink)
montsa007's Avatar
i dont know how to do this???
Old 03-06-2005, 05:58 PM   #9 (permalink)
mariner's Avatar
may sound absurd but did u have ne floppy in the floppy drive while starting up? remove that and try again.
mariner is offline
Old 03-06-2005, 06:14 PM   #10 (permalink)
montsa007's Avatar
no floppy present i tried 2 3 times but it wont start its a p1
Old 04-06-2005, 08:24 AM   #11 (permalink)
q3_abhi's Avatar
Try 2 use a new floppy
q3_abhi is offline
Old 04-06-2005, 12:29 PM   #12 (permalink)
agreed , very much but this first step doesnt necessarily a boot floppy.
Invalid system disk replace the **** means check your bios pressing delete several times when u hear two beeps indicating the system has started.
Now goto advanced settings and check for the first boot device. If its ok , then check using Esc+Tab.(press the sequence repeatedly)
If u see the hdd is detected(some info like your hdd brand with serial no) for example if its seagate is goes like ST XXXXX where x is number.
If its not detected , agin press delete enter setup and goto cmos settings and check (the four devices primary master/slave and secondary master/slave)
If yo hdd isnt detected, then config manually.
If this too is ok, see in Peripherals tab for a option called Primary IDE , if this is disabled this can also cause such a error. These are three common problems faced with this kinda error.
I DO NOT RECOMMEND ANY OF THE ABOVE TO NOVICE WINDOWS USERS, ITS FOR INTERMEDIATE USERS WHO HAVE ADEQUATELY PLAYED WITH WIN OS FOR A WHILE. IAM NOT TO BE HELD RESPONSIBLE FOR THE PROBLEMS FACED BECAUSE OF DOING THIS. I AM JUST SUGGESTING THIS SOLUTION , NOT FORCING IT
Any questions plz get back to me or pm me.
Hibernating ....
banned2wise is offline
Old 05-06-2005, 02:13 PM   #13 (permalink)
tell how many hdd's do u have?
if u have 2 then go to BIOS and change u r second device from hdd0-hdd1
or try boot ing from other media as mentioned by others
upendra_gp is offline
Old 06-06-2005, 11:16 AM   #14 (permalink)
montsa007's Avatar
1 hdd seagate 10.2gb i think i will sell it well thanks all you guys i feel i am between frends for life but i am calling a guy (engineer) to update this and also repair
ALSO THANKS A LOT I FEEL SO HAPPY
