Old 16-01-2009, 10:48 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default 6gb iso file to copy to 8gb transcend drive
i have a 6GB iso which when i try to upload to my 8gb pendrive it says disk full, the drive is empty and has 7.4 free space. i tried formating the drive and tried with the same result, the drive i connected to the back pannel of my PC. windows XP is my OS. what could be the problem?
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 16-01-2009, 10:58 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: 6gb iso file to copy to 8gb transcend drive
FAT/32 supports maximum 4GB file size.
Convert drive to EXT2 or NTFS(with journal disabled).
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 16-01-2009, 11:09 PM   #3 (permalink)
chicha's Avatar
oh god thank you. but what is journal disabled?
chicha is offline
Old 16-01-2009, 11:34 PM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
flash storage wears out on write cycles , not on read cycles.
fat 32 is is a non-journaling file system.
ntfs is a journaling file system.
ntfs causes more more write cycles on flash drive than fat32 to copy same amount of data.
thus it should be avoided.
gary4gar is offline
Old 16-01-2009, 11:49 PM   #5 (permalink)
The Smaller Bang
Thats why I said try to disable journal on NTFS.
But I think EXT2 is the best choice for a flash drive's file system. It supports files of ANY size and is not journalising.
Old 17-01-2009, 05:35 AM   #6 (permalink)
Norms Buster
But can EXT2 be used under Windows environment ?
VexByte is offline
Old 17-01-2009, 08:25 AM   #7 (permalink)
chicha's Avatar
^ exactly the reason i mentioned i was using win xp. but thank you all.
chicha is offline
Old 17-01-2009, 09:34 AM   #8 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Sorry for sounding noobish, but how exactly do you disable journal on an NTFS drive?
kalpik is offline
Old 17-01-2009, 11:16 AM   #9 (permalink)
damked's Avatar
There is a software called ext2fs which can read and write to ext2 partitions in windows.
damked is offline
Problem in Transcend USB Drive of JF V10 januseenu Software Q&A 2 07-10-2008 09:47 PM
Problem with Transcend 8 GB Pen Drive mrbgupta Hardware Q&A 9 22-02-2008 04:47 PM
mFormat for Transcend 2GB usb drive almighty Software Q&A 2 03-10-2007 01:23 PM
Transcend T sonic 610 as pen drive? suyash_123 QnA (read only) 18 08-01-2007 09:38 PM
