Old 02-06-2005, 11:45 AM   #1 (permalink)
Maverick340's Avatar
Default Demytify The RAM
I have a Intel D845GVSR motherboard ...
I am currently using a 128 MB DDR RAM ...i am not sure where to find its speed ..so pls tell me..
Also i wanted to upgrade my RAM to 512 Mb...
is there any Speed limit of my motherboard....i mean can i put a PC400 DDR RAM on my PC....
I am also not very clear about the RAM Speeds so pls help...
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 02-06-2005, 12:48 PM   #2 (permalink)
expertno.1's Avatar
well bud get info from here
u will be answerd will all your questions :-
http://www.pricegrabber.com/search_t...78#description
http://www.intel.com/design/motherbd...4pmb_d845gvsr&
expertno.1 is offline
Old 03-06-2005, 12:45 PM   #3 (permalink)
what abt diff RAM Speeds.....
PSpwned
Old 03-06-2005, 01:35 PM   #4 (permalink)
The Incredible's Avatar
Visit ur mobo manufacturer's site.
Search with ur mobo model name or find da section for product information.
when ur product info will be given. u can there find abt da RAMs ur mobo supports.
Bye.
The Incredible is offline
Old 03-06-2005, 01:40 PM   #5 (permalink)
expertno.1's Avatar
ram speed depends upon the motherboards capacity
if ur ram is 400 hz and motherboard supports only 333hz then u will be unable to run that ram on 400hz
u will have to low down the value
Old 03-06-2005, 07:52 PM   #6 (permalink)
Any software which can tell me my Ram speed??
PSpwned
