Originally Posted by tuxfan
BTW, what will you use? VB and Access? Or C and MySQL? Or something else?
Do u need all those RDBMS stuff for simple reminder program ?
A simple txt/ini/xml file will be more than enough. Front end can be in
VB/C or better in delphi.
I don't think a DLL dependency is required if Delphi is used. But I don't know delphi, if some1 knows, best luck.
But I still fill, rainlender is enough for this type of reminders.
