Old 02-06-2005, 10:10 AM   #1 (permalink)
pradipudhaya's Avatar
Default Bad Clusters
What are bad clusters and how are they formed?
pradipudhaya is offline
Old 02-06-2005, 12:23 PM   #2 (permalink)
ferrarif50's Avatar
bad clusters normally represents lost or fragmented data, which is not linked. This can happen due to many reasons. Even frequent power failures can cause this thing to occur.
You can prevent this by regularly defragmenting your harddrive, organizing all stuff in ur comp in proper directory structures etc.
My time machine will take you one hour into the future in only sixty minutes!
ferrarif50 is offline
Old 02-06-2005, 03:40 PM   #3 (permalink)
How do I find whether I have bad clusters?
Old 02-06-2005, 04:58 PM   #4 (permalink)
Use scandisk
In Win 98SE go to start>programs>accessories>system tools>scandisk
In Windows XP use chkdsk
go to start >run and then type cmd and press enter. Then in the window that opens type chkdsk and then press enter
It is better to light a candle than to curse the darkness.
Shikhar is offline
Old 02-06-2005, 07:37 PM   #5 (permalink)
ramprasad's Avatar
Hi
Bad sectors are also caused by physical damages also.. The best way to patch the bad sectors is to use the tool provided by the manufacturer himself.. like SeaTools for Seagate Disk...
Regards,
Ramprasad
ramprasad is offline
Old 02-06-2005, 07:47 PM   #6 (permalink)
I did chkdsk.... It said that there are 0 bytes in bad sectors... which means, I may have a bad sector right?
Old 02-06-2005, 08:26 PM   #7 (permalink)
hai,
Bad clusters are basically formed because of defect in physical manufacturing. they can also b formed because of physical damage. windows in built tools like scandisk and disk defragmenter can tell u about how many r there and how much space is taken up by them.
raghug is offline
Old 02-06-2005, 08:27 PM   #8 (permalink)
that means there r no bad sectors in your hard disk. no need to worry..
raghug is offline
