I have a 20gb samsung Hardisk. Recently ,I have started getting n error-
SMART: Failure detected on ur hard drive.Immediately Backup ur harddrive n replace it. Then i have 2 press F1 2 continue. After pressing F1 computer starts normally. I found no such option in bios to disable it Such as SMART Capability . What should be done????
well bud..SMART is an Feature of Bios : This option enables/disables support for the hard disk's S.M.A.R.T. capability. The S.M.A.R.T. (Self Monitoring Analysis And Reporting) technology is supported by all current hard disks and it allows the early prediction and warning of impending hard disk disasters. You can enable it if you are using S.M.A.R.T. aware utilities to monitor the hard disk's condition. Enabling it also allows the monitoring of the hard disk's condition over a network.
SO if ur Getting This Error..i will suggest Do the Backup......and Get ur HDD Checked by Proffesionals..also che This .....
