Old 11-01-2009, 12:04 PM   #1 (permalink)
Default files names are in blue color
Hi,
In my windows xp sp2, suddenly i found so many files name converted into blue. I search into net, reason is if u don't use that file for long time it automatically compressed. I don't want this facility. How to disable this feature, plz tell me. second thing is, any of the pdf file which turns into bule file name, i am not able to open using acrobat reader 8. it says, either file is damage or not downloaded properly. but that is not a case. files are proper i know. now how can i uncomress again. note pad files open in notepad without any problem.
anni is offline
Old 11-01-2009, 12:25 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: files names are in blue color
blue color -> compressed files
green color -> encrypted files
Open my computer -> Tools -> Folder Options -> View -> uncheck "Show encrypted or compressed NTFS files in color" -> Apply -> ok
ravi_9793 is offline
Old 11-01-2009, 09:55 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Also, the blue color maybe tat u must be having an NTFS partition (onto wich these files are stored) as files in an NTFS partition are also colored blue...
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 11-01-2009, 10:20 PM   #4 (permalink)
raksrules's Avatar
BLUE color files means that they are Blue Films (p0rn) disguised as some other unrecognizable files. Lolzzz
But seriously i dont have clue... just couldn't resist replying
raksrules is offline
Old 12-01-2009, 12:27 AM   #5 (permalink)
asia://india/ka/bangalore
a_to_z123's Avatar
NTFS partitions do not necessarily have Blue Coloured file names.
Its when u enable compression.
N compression is on the HW level where the actual file system works. When u use the file it acts like any other normal uncompresed file. The OS duznt require user intervention for compression/decompression.
The PDF files which r corrupted r in fact actually corrupted. Download them again man!!!
:) I've got my F, C and K . Now all I need is You !!! :)
a_to_z123 is offline
Old 12-01-2009, 09:03 AM   #6 (permalink)
Thanks for reply. I am using NTFS partiotions. But how can i uncompress again. As i am not able to open my pdf files. Others i am able to open
anni is offline
Old 13-01-2009, 12:23 AM   #7 (permalink)
a_to_z123's Avatar
* Go to 'My Computer'
* Go to the drive/folder which you want to decompress.
* Right-click-->Go to 'Properties'
* If you're decompressing a whole drive then in the 'General' tab, you'll see at the bottom 'Compress drive to save disk space'
* Uncheck it and click 'OK'
* It'll take some time to decompress the whole drive contents as it applies the new attributes.
* On the other hand, if you're decompressing any file/folder then in the 'General' tab you'll see the 'Attributes' section.
* Click on 'Advanced'.
* There also uncheck the same option as mentioned above.
* There you have uncompressed file/folder/drive.
* Now they are listed in Black colour!!
That's it!!!!
And still if your PDF files don't work as I've told you earlier (and that certainly the case is), the files are themselves corrupted and you did the decompression in vain. So you'll have to get those PDF files again from where you got them....
Happy decompression session mate!!! B-)
Old 13-01-2009, 04:51 PM   #8 (permalink)
Lol... wat a reply !! Bravo bravo..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
How to play Blue Ray media Files? max_demon Software Q&A 2 13-06-2008 07:01 AM
Drive letter and folder names turn blue windchimes Software Q&A 4 14-03-2008 07:33 AM
```Blue Color DVD is not working on my DVD ROM!! kool QnA (read only) 25 18-09-2006 06:12 PM
Windows File Names Show Up In Blue! ravillion10 Software Q&A 3 25-08-2006 09:10 AM
how to put small blue color image under the name QnA (read only) 4 07-04-2005 06:55 PM
